Coolant lines going to throttle body and idle/air sensor?
I don't have any coolant lines going to my TB and idle/air sensor. Is that bad? My car is cold blooded in the mornings. If I run these coolant lines to them will that fix it?
i bypass my throttle body but i run the line from the thermo housing straight to the iacv on the back of the intake . you should run your lines to the iacv atleast . it helps car idle better .
dem0nk1d
14
Mar 22, 2006 05:57 PM
smash fascism
Apr 10, 2005 06:39 AM
