Questions on KGMM springs
I'm wondering how many people here run the KGMM sport and race springs on their ITR?
also i'm looking for spring rates for both of them too and if possible can you post pics of your R with the springs and which springs you're using
TIA
btw: i did a search already and came up with 6 threads...with not enough pics
TIA
I had them on my ITR a long time ago. I sold them for some Tein HAs and now will be buying another set of KG/MM suspension, but this time i will be going w/ the FS Damper not just springs.
You have to remember that you are just buying springs, so the actual benefit is very minimal, other than a lowered look. The springs dont drop the car too much, very similar to the Spoon Springs. If you can find pictures of cars lowered on Spoon springs, the KGMM will look very similar.
Check with aj-racing for more details
According to http://www.kgm.co.jp, the DR21 Supersport spring will lower 30mm front and 25mm rear. Compare with the DR Racing which will lower 35mm up front & 30mm rear.
Spring rate wise:
Original(F/R) Primary(F/R)
DR 21 Supersport: 6.6k/4.8k 3.6k/2.4k
DR Racing: 8.2k/6.4k 3.8k/2.8k
They work well with Bilstein & KYB AGX(& SPOON dampers if u can find any in good shape
). But still they are not bad with ITR stock suspension, just that it's recommended to change over to sport shocks to get the best performance out of them.
Spring rate wise:
). But still they are not bad with ITR stock suspension, just that it's recommended to change over to sport shocks to get the best performance out of them.Trending Topics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibuprofen »</TD></TR><TR><TD CLASS="quote">
kgmm s21
you can buy them at http://www.ipsracing.com. if you need other angles, lmk
sexaY ITR
kgmm s21
sexaY ITR
this might help w/ my kg/mm back then..sorry i dont know how to post a pic here.
http://www.imagestation.com/my...grass
http://www.imagestation.com/my...eback
