Question for JDM SRS Momo steering wheel owners...
Old Dec 8, 2003 | 04:57 PM
machgo5go's Avatar
Default JDM SRS Momo Steering Wheel owners
I am sorry to ask frequent question and gain much from search.
Just for double check, does the wheel only comes with a big yellow Airbag connector with a Short connector also Yellow for mating with the cable reel connector?
I have an much older 94 integra helm manual and it show USDM Airbag connector also yellow but the Short connector being Red instead.
Thanks for inputs.
Y2K FBP R #415
Old Dec 8, 2003 | 06:42 PM
jdmspoonitr's Avatar
Default Re: JDM SRS Momo Steering Wheel owners (machgo5go)
I believe the connectors are different. You are going to have to cut and solder. The wheel plugged into my 01 straight up. But I remember my friends 95 gsr had a different srs plug.
Old Dec 8, 2003 | 06:59 PM
bcrl's Avatar
Default Re: JDM SRS Momo Steering Wheel owners (jdmspoonitr)
JDM SRS Momo Steering Wheel will direct bolt on to the ITR without need to do any changes for the USDM ITR SRS wiring?
Old Dec 8, 2003 | 07:13 PM
machgo5go's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote"> The wheel plugged into my 01 straight up. </TD></TR></TABLE>
So my 00R should be just plug and play? Horn and SRS works?
Old Dec 8, 2003 | 07:15 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go &raquo;</TD></TR><TR><TD CLASS="quote">So my 00R should be just plug and play? Horn and SRS works?</TD></TR></TABLE>
You are correct, everything should work.
Old Dec 12, 2003 | 07:13 AM
bcrl's Avatar
Default Re: JDM SRS Momo Steering Wheel owners (dc231)
JDM SRS Momo Steering Wheel:
For 98-01 ITR should be just bolt on as well? Horn and SRS both work, right?
Old Dec 12, 2003 | 12:41 PM
bcrl's Avatar
Default Re: JDM SRS Momo Steering Wheel owners (bcrl)
Old Dec 12, 2003 | 12:43 PM
bus stop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bcrl &raquo;</TD></TR><TR><TD CLASS="quote">JDM SRS Momo Steering Wheel:
For 98-01 ITR should be just bolt on as well? Horn and SRS both work, right?</TD></TR></TABLE>
YES
more like change a tire......
dc2rphoenix
Feb 25, 2019 02:46 PM
natman316
Apr 13, 2011 10:26 PM
tremor86
Nov 14, 2004 06:52 PM
