oil pressure problem
hey all, have a problem, i changed the oil on my car and when i started it up the oil light stayed on.
i checked the level and it was fine, don't know if something is clogging the passages. i am going to pressure test it when i get the pressure gauge
any ideas??
thanks
any ideas??
thanks
**** **** ****, the problem was the damn k&n oil filter. did not allow oil to flow and cause my cam bearings to get fcuked, put back a stock honda oil filter and changed the oil. got alot of brass metal shavings from the oil.
**** **** ****, i'm pissed off.
car still runs decent, i will changed the oil and oil filter another two times this week to get out all the brass shavings. then i will see how bad the damage is.
******* k&n filter, do not use if you have a B&M oil filter relocation kit on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostlee »</TD></TR><TR><TD CLASS="quote">**** **** ****, the problem was the damn k&n oil filter. did not allow oil to flow and cause my cam bearings to get fcuked, put back a stock honda oil filter and changed the oil. got alot of brass metal shavings from the oil.
please explain what the problem was, kit or user error
</TD></TR></TABLE>please explain what the problem was, kit or user error
bad K&N oil filter, was restricting the oil flow somehow. i have used the k&n oil filter in the stock location but never with the oil relocation kit.
when i put on a new honda oil filter.....bam oil pressure light went out and i had oil pressure.
something so simple, but i never would of thought, partly my fault
v8killaz
Nov 20, 2009 03:21 PM
