b20 block or head work?
Old Dec 8, 2003 | 01:44 PM
veryslowcx's Avatar
Default b20 block or head work?
i got to make a decision by Febuary, my car is out of because of a distributor problem right now but it will be up and running soon. while it is out i will be doing alot of things to it or maybe thinking bout it 15 hundred to spend and i was thinking of either doing a crvtech (b20 block/b16 head) either that or spend almost the same amount with a skunks stage 2 cam, skunks cam gears, unorthodox pullys. can't decide yet. i want to stick with the allmotor and want to do something cheap and make my cx faster than what it is right now.
Old Dec 8, 2003 | 05:18 PM
Miracle_X_Bar's Avatar
Default Re: b20 block or head work? (veryslowcx)
go B20....everyone else is!?!
Old Dec 8, 2003 | 05:22 PM
JCushing's Avatar
what do you have rigth now though?
Old Dec 8, 2003 | 06:11 PM
infamousR13's Avatar
Definetly B20. You can get a shortblock for about $900. I know two guys that steped up from ls/vtec to cr/vtec, and the power and torque gains are sweet. It is definetly noticeable, especially if you are steping up from a b16. Just make sure you do it right and don't cut corners.
Old Dec 8, 2003 | 06:43 PM
vtecvoodoo's Avatar
Future Texas Boy
b20
Old Dec 8, 2003 | 09:20 PM
DVS_EF's Avatar
B20 that *****'...........just be sure you get the right block with the higher compression slugs in it... i think the b20z?... i dunno, .... blah'
my ride http://www.backseatbangers.com
Old Dec 9, 2003 | 01:46 AM
Fkned's Avatar
Default Re: b20 block or head work? (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">what do you have rigth now though?</TD></TR></TABLE>That's my first question also,I'm assuming that you already have the B16 and are asking if it would be better to rebuild it with the skunk parts or build a crvtec B20 hybrid?correct?If this is the question I'd say CRVtec,no replacement for dissplacement as they say.
Jhobs3
Feb 4, 2013 10:45 AM
spens 91 Ef
Oct 29, 2009 11:40 AM
rare_db2
32
Jul 27, 2007 01:10 PM
90civichbsi
Mar 30, 2003 07:00 AM
