Suspension help.... How to reduce OVERSTEER especially at high speeds?
Old Sep 18, 2001 | 09:16 PM
TurboIntegra's Avatar
Default Suspension help.... How to reduce OVERSTEER especially at high speeds?
So my setup currently is:
Tein HA's
Stock Swaybars
Brand new Kuhmo tires on stock rims
My problem is this; at very high speeds the back end feels very light and unstable. Under very hard braking it sometimes feels like it is going to whip around. And if I were going at a fast rate of speed and there is even a slight curve, the back feels like it is going to whip around.
This was also a problem with my old LS integra, not just my Type R.
How can I combat the oversteer at high speeds?
Thanks for your help, because I know very little about suspension setups.
Old Sep 18, 2001 | 09:30 PM
SpecR_EK's Avatar
New User
Default Re: Suspension help.... How to reduce OVERSTEER especially at high speeds? (TurboIntegra)
Whats the settings on your Teins?
Old Sep 18, 2001 | 10:02 PM
Big Phat R's Avatar
Mugen rear wing set to maximum downforce
Old Sep 18, 2001 | 10:07 PM
Andrew Sites's Avatar
Stiffen your front shock settings and soften the rear settings -- if you can, I don't know much about Tein.
Old Sep 18, 2001 | 10:11 PM
Default Re: Suspension help.... How to reduce OVERSTEER especially at high speeds? (Andrew)
Once last thing...
I don't mean to sound condescending, but I would NOT listen to that Stu guy in the Integra forum. The BS seems to be getting a little deep in there.
https://honda-tech.com/zerothread?id=70031
Old Sep 18, 2001 | 10:51 PM
onyx00's Avatar
I remember asking the same question and someone said if your backend is flipping around at high speeds and you need more downforce in the back the answer is simple: You are going too fast.
Old Sep 19, 2001 | 03:22 AM
COREY ITR#625's Avatar
Default Re: Suspension help.... How to reduce OVERSTEER especially at high speeds? (onyx00)
I have my N-1's set at 7 in the front and 5 in the back and I don't have a problem with oversteer. BTW, what is the highest settings on the Teins?
Old Sep 19, 2001 | 04:28 PM
travis's Avatar
Default Re: Suspension help.... How to reduce OVERSTEER especially at high speeds? (COREY ITR#625)
First of all, heavy breaking usually shouldn't be done in the middle of a corner anyway, so that might help you out a little. If the back end feels like it's going to whip around while breaking, you need to straighten the wheel. Also, if you could describe your breaking/turning technique, we might find the problem there and not in your setup. Finally, which Kumhos?
[Modified by ITR#231, 5:34 PM 9/19/2001]
Old Sep 20, 2001 | 07:50 AM
Hracer's Avatar
New User
High-speed twitchiness can be caused by bad alignment with too much toe-out in either front or back. Heavy braking with excessive toe-out will result in the car darting left to right, if that's what you're experiencing.
Other than that, I've driven the type r on both kumho v700s and the kumho street tires around a couple of tracks and to a certain degree the back does like to hang out in faster turns. As long you keep it in check, it shouldn't whip around. The type r is the most neutral and prone to rotation out of all the (few) near stock or stock cars I drove around a track.
Make sure you have your alignment checked - the problem you describe happens quite often to our IT racecars and it's usually due to bad alignment. Good luck!
[Modified by Hracer, 11:51 AM 9/20/2001]
bobseger
Jan 14, 2007 09:47 PM
SuperRice
Sep 7, 2002 09:03 PM
wuggiewuggie
Jun 6, 2002 03:10 PM
TurboIntegra
Sep 19, 2001 06:54 AM
