Yes! My JDM DC SPORT SS HEADER arived today, but I have just a few questions.
Old Sep 18, 2001 | 07:35 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Yes! My JDM DC SPORT SS HEADER arived today, but I have just a few questions.
Its an awsome looking header, I'm in love. I know I need a 2.5" highflow cat, and
from what I hear car sound cat is the way to go, but is there a certin model I
should get? Also will this header and cat bolt right up to my stock excaust or do I
need to modify it? Last should I get 2.5" straight pipe to stock mufler or is it not
worth it. I don't plan on going much further than intake (done), header, Highflow
cat, and possible excaust, and I don't want to lose power, or will the straight pipe
make more power on my basically stock R. Thanks in advance for your reply.
Old Sep 18, 2001 | 07:39 PM
Bob#455's Avatar
Default Re: Yes! My JDM DC SPORT SS HEADER arived today, but I have just a few questions. (01PYTypeR#1140)
Talk to Mike @ IPS Racing (TypeRmsm)...he should be able to hook you up with a Carsound cat for your application!
Old Sep 18, 2001 | 07:44 PM
Jason's Avatar
if you purchase the 2.5" straight through cat (i believe model # 94006) you will need an adapter for your current exhaust...this will benefit you in another way as well, by removing the first bottleneck in your stock exhaust. Also, it will allow you to bolt on a 2.5" exhaust at a later date...
I too, have done the same and definitely recommend it!
Old Sep 18, 2001 | 08:00 PM
Default Re: Yes! My JDM DC SPORT SS HEADER arived today, but I have just a few questions. (typer98)
would it be ok if I get the header & carsound cat installed, and just weld 2.5" straight pipe all the back to stock excaust? Or is it for some reason better to get the adapter with the 2.5" straight pipe to stock muffler? Does anyone know of the pros & cons with these setups?
Old Sep 18, 2001 | 08:59 PM
hybrid_KJ's Avatar
Has anyone seen a dyno graph comparing the jdm dc to the jdm 4-1 itr header? What about caompared to other jdm and performance headers?
Old Sep 18, 2001 | 09:06 PM
Mike M's Avatar
Founding Member
Actually If you are referring to making a new B Pipe going to your stock exhaust then Yes that is better Much better
Old Sep 19, 2001 | 01:13 AM
Unlimited's Avatar
New User
Default Re: Yes! My JDM DC SPORT SS HEADER arived today, but I have just a few questions. (TypeRmsm)
is $380 good price for jdm dc ss header?
Old Sep 19, 2001 | 03:23 AM
Zeus's Avatar
...look for SMSP as I think his 2.5" CarSound is around $180ish with all gaskets and hardware... can't remember if that includes the 2.5" reducer to get rid of the restriction right after the cat...
Old Sep 19, 2001 | 03:28 AM
SMSP's Avatar
A modded 94006 will bolt right in. Now if you plan to run the stock exhaust for a while I would recommend one of my adapters also. However, if you go with all 2-1/2" tubing from the cat to the stock muffler without using a resonator, your exhaust will sound more raspy. Note, even if you go with 2-1/2" tubing it will still need to be enlarged slightly at the B flange so there is a smooth transition from cat to B pipe. If you will only run a test pipe this is not required.
[Modified by SMSP, 5:17 AM 9/19/2001]
Old Sep 19, 2001 | 04:07 AM
Jason's Avatar
that's essentially what you're doing by getting the adapter...what the adapter is, is just a 2.5" flange that tapers down to 2 1/4", which then needs to be welded to the stock exhaust...in order to do this you need to cut the current flange off of the stock exhaust....
a) it gets rid of the bottleneck
b) you need a 2.5" flange to mate up to the carsound cat...
Old Sep 19, 2001 | 06:11 AM
98itr896's Avatar
Default Re: Yes! My JDM DC SPORT SS HEADER arived today, but I have just a few questions. (hybrid_KJ)
yes, this is what we would like to see! someone with a dyno can surley get the headers from the manf for free for testing purposes and send them back when finished.
Old Sep 19, 2001 | 06:24 PM
Thanks guys you've all been a great help. Anyone else have some input on this topic?
Old Sep 20, 2001 | 06:23 PM
I hear that I need a flex pipe between my JDM header and highflow cat, because of front wheel drive. Is this true? wont this affect the flow of my excaust?
schumi
Jul 23, 2005 09:14 AM
98cwitr
Sep 4, 2003 10:17 AM
98civicEX
Mar 10, 2003 07:42 AM
pistol
Nov 26, 2002 11:26 AM
NSX Bob
Sep 7, 2001 03:55 AM
