Brake light shortage
I have a problem. everytime i hit my brake pedal my brake light fuse breaks. Would that be because i have a bad ground or because the solenoid on the pedal is bad? i don't understand how all of sudden it would start f'n up. My taillights work tho....could some help me?
I'm a little unclear about what you mean about the break fuse. But anyhow I had a problem earlier this year, when I hit the brakes all the power in the car went out (radio, gauge cluster etc.) well it turned out to be a loose battery terminal, so check that out, and if that's it then congrats, but if it isn't keep looking. But it won't hurt to try it.
Good luck
Good luck
dbailey
Jul 25, 2010 10:24 AM
