How much do ITR internals weigh?
Old Dec 7, 2003 | 05:43 PM
done's Avatar
Default How much do ITR interals weight?
I found stock weight of pistons and rods. Thanks typer.og
Stock piston = 307 grams
Stock Rod = 556 grams
exhaust valve = 19 grams
intake valve = 28-30
How much do stock valves and valvetrain weight?
Modified by Jordo at 11:43 PM 12/7/2003
Old Dec 7, 2003 | 07:57 PM
D's Avatar
D
Default Re: How much do ITR interals weight? (Jordo)
exhaust valve is about 19 grams if i recall correctly..
intake is around 28 or 30... can't remember.
D
Old Dec 7, 2003 | 08:36 PM
IN VTEC's Avatar
I've taken the masses of 3 different sets of ITR rods. The lowest I've seen is 544g and the highest being 553g. The median mass is definitely 546g tho.
Masses taken with stock rod bolts & nuts installed, no bearings, and no wrist pins.
Old Dec 7, 2003 | 08:44 PM
done's Avatar
Default Re: How much do ITR interals weight? (IN VTEC)
Ok lets have a bit of discussion fellas..
Wont lighter engine parts make the motor more responsive?
Old Dec 7, 2003 | 09:00 PM
IN VTEC's Avatar
1lb = 453.59g and 1g = .0022046lb
Each rod weighs in at around 1.2 lbs. There's not much weight to be saved on the rods.
Even with forged rods that advertise 15% less mass than stock rods, that's only going to take .15lbs off of each rod. You'd probably save equally about the same going with typical, mass-market forged pistons. All together, you'd shave around 1.20lbs from the rotating assy.
Every little bit helps, but probably not as much as you'd think.
It's easier to find responsiveness through power delivery than lightening the bottom-end assy....theoretically speaking.
Old Dec 7, 2003 | 09:02 PM
IN VTEC's Avatar
Forgot to add that every OEM Honda wrist pin I've ever taken mass of was 88g.
Old Dec 7, 2003 | 09:05 PM
done's Avatar
Wont lighter valvetrain help also?
Old Dec 8, 2003 | 02:25 AM
Pondus's Avatar
When using lighter pistons and rods shouldn't you also remove some weight from the counterbalances on the crank to counter this, and have the crank rebalanced? If so you'll save even more weight on the bottom end, and every little bit helps.
michaelprice83
Oct 10, 2008 09:16 AM
GO-FIGHT-KILL
Feb 20, 2008 06:18 AM
ActiveAero
24
Jan 14, 2004 10:27 AM
Dammit_Dan_954
Nov 30, 2003 11:18 AM
schwett
Apr 24, 2002 10:43 PM
