Help: Suspension on my EG
Old Dec 7, 2003 | 04:29 PM
BoostinEJ1's Avatar
Default Help: Suspension on my EG
I'm not all to smart when it comes to the suspension of cars , in any case... I just bought some used Neuspeed Race Springs for my 93 Si and I have been told that the drop isnt any more then 2 inchs or so in the front and rear. I just wanted to know if I will need a camber kit for either front or rear, and how long can i go with stock shocks. Anyone with pictures of their Eg's with these springs? Thanks in advance for the help .
Old Dec 7, 2003 | 04:31 PM
clm's Avatar
clm
Default Re: Help: Suspension on my EG (JdmEGHatch6)
Some people last a month on stock shocks and others a lot longer. Just depends I guess.
I wouldn't worry about a camber kit until you know you need one.
Old Dec 7, 2003 | 05:40 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Help: Suspension on my EG (clm)
How much do you like bouncy suspension.
Old Dec 7, 2003 | 05:52 PM
BoostinEJ1's Avatar
dont knwo, first time having a car lowered
Old Dec 7, 2003 | 05:53 PM
TorganFM's Avatar
What is camber exactly?
Old Dec 7, 2003 | 06:00 PM
The G2 Racer's Avatar
Default Re: (TorganFM)
I had those springs on my old EG and had some bad *** camber, didn't bug me much though. I'd look into a camber kit though.
My stock shocks lasted about 6 months but if you have the money, replace the shocks asap.
Old Dec 7, 2003 | 06:33 PM
The Internet Tough Guy's Avatar
Default Re: (The G2 Racer)
you don't need a camber kit. camber does not eat tires that much at all (a tiny bit). after you get your springs on, you'll need an alignment, and get your TOE set to 0 all around. TOE is what eats tires - not camber. the only reason you should get a camber kit is if you want to run a specific degree of negative camber, or you're real **** about your tires.
Old Dec 7, 2003 | 07:19 PM
BoostinEJ1's Avatar
this TOE, is this something i do myself or i have done when i get the alignment done? thanks.
Old Dec 7, 2003 | 07:25 PM
Cookie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TorganFM &raquo;</TD></TR><TR><TD CLASS="quote">What is camber exactly?</TD></TR></TABLE>
cam·ber ( P ) Pronunciation Key (kmbr)
n.
A slightly arched surface, as of a road, a ship's deck, an airfoil, or a snow ski.
The condition of having an arched surface.
A setting of automobile wheels in which they are closer together at the bottom than at the top.
Old Dec 7, 2003 | 08:20 PM
Default Re: (JdmEGHatch6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEGHatch6 &raquo;</TD></TR><TR><TD CLASS="quote">this TOE, is this something i do myself or i have done when i get the alignment done? thanks.</TD></TR></TABLE>
it's one of the 3 angles you can adjust when you get an alignment. well, actually 2 if you don't have a camber kit.
wheel with 0 camber
wheel with camber
<FONT COLOR="fafafa">.</FONT>/=/ <FONT COLOR="fafafa">..</FONT> \=\
/=/ or<FONT COLOR="fafafa">..</FONT>\=\
Old Dec 7, 2003 | 08:27 PM
BoostinEJ1's Avatar
thank you
Old Dec 7, 2003 | 09:36 PM
Default Re: (japoneeZ)
caster is what makes your car not go straight right???
like this would be the bottom view of a car with caster:
front wheels: /=/------------/=/ (or the opposite direction)
right?
wtf is toe?
Old Dec 7, 2003 | 09:49 PM
BoostinEJ1's Avatar
now i have to decide on shocks
either Koni Yellows, a bit much for my budget, or Bilstein Heavy duty shocks which are a bit cheaper, anyone?
Old Dec 7, 2003 | 10:35 PM
clm's Avatar
clm
Default Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf is toe?</TD></TR></TABLE>
Toe is the "in" and "out" positioning of the wheel.
Caster is the "forward" or "backward" positioning of the wheel.
Camber was already answered.
Old Dec 7, 2003 | 10:41 PM
Default Re: (clm)
im an idiot.... i dont understand what you mean by in and out, forward or backward.
could you explain a little deeper please?
Old Dec 7, 2003 | 10:44 PM
clm's Avatar
clm
Default Re: (jwn7)
I'll try and find a link...
w00t! Here's one: http://tirerack.com/tires/tire...n.htm Even has some nice pictures.
Old Dec 8, 2003 | 12:43 AM
Default Re: (clm)
that was great. thanks a lot
neonracer2k5
Suspension & Brakes
Oct 2, 2016 05:51 PM
hC_858
Suspension & Brakes
Nov 8, 2008 09:06 AM
originalg00kster
Suspension & Brakes
Sep 24, 2007 12:47 AM
dawrenn
Suspension & Brakes
31
Jan 26, 2005 09:52 AM
92LudeSI
Feb 27, 2003 07:42 PM
