questions about shifting
Old Sep 18, 2001 | 04:34 PM
GSR1ner's Avatar
New User
Default questions about shifting
Hey all,
I was wondering if you guys encountered this...
Everytime I shift from 2nd to 3rd in my GSR, it clicks into 3rd gear, it's hard to explain but it does not shift smoothly as before. Has this happened to anyone else?
Old Sep 18, 2001 | 04:35 PM
GSR1ner's Avatar
New User
Default Re: questions about shifting (GSR1ner)
I was just wondering what the cause of this was
Old Sep 18, 2001 | 07:53 PM
vteg's Avatar
New User
How many miles since you changed your tranny fluid?
Old Sep 18, 2001 | 08:26 PM
gsxr's Avatar
Default Re: questions about shifting (vteg)
is it easy to change the tran. fluid on a manual?
Old Sep 20, 2001 | 05:12 PM
GSR1ner's Avatar
New User
Default Re: questions about shifting (gsxr)
Hey Guys,
Thanks for your help. Well the car is pretty new...less than 5,000 miles
But I took it to the dealer today and he test drove it with me and said everything
was fine. He says it is normal for it to click..
Thanks
Old Sep 20, 2001 | 07:31 PM
WetwurkzGSR's Avatar
New User
Yeah, this just happened yesterday. When i shifted into third, it just felt not completly in. Freaked me in a lil bit, but it should be fine.
Old Sep 20, 2001 | 07:41 PM
slowerthanu's Avatar
New User
Default Re: questions about shifting (WetwurkzGSR)
A little CLICK is okay it is more than likely just the notchiness, a grind though is not.
Old Sep 20, 2001 | 07:46 PM
P73 DA9's Avatar
New User
Default Re: questions about shifting (slowerthanu)
It isnt that bad if it grinds going into 3rd, just get used to it or turn up your stereo so you dont notice it as much.
Old Sep 20, 2001 | 08:57 PM
GSR1ner's Avatar
New User
Default Re: questions about shifting (blueG2)
This may be a dumb question, but how do you know if you're grinding the gears...
This is my first manual car.
Old Sep 20, 2001 | 09:00 PM
vteg's Avatar
New User
You will hear it, and feel it, and girls on the street will notice you too It is literally a grind. When it happens you will know.
Old Sep 21, 2001 | 01:03 AM
Key's Avatar
Key
New User
i did this a few times when i started stick myself, it literally goes GRRRR and you can feel it grind like teeth on gears. happened whenever i didn't shift all the way, feel like hell, thought i'd completely killed it
Old Sep 21, 2001 | 01:42 AM
Anthony K's Avatar
New User
Sometimes I encounter notchiness like you did...make sure you change your tranny fluid after about 40-45000 miles I believe. Use Honda MTF or maybe even Redline.
IgniteTeg's Avatar
Default Re: questions about shifting (Key)
A grind will be very noticable. Its hella loud and many people around you can even hear it heh.
Old Sep 21, 2001 | 06:26 AM
samagon's Avatar
when you are grinding your gears, people like me will be standing off to the side cheering you on, and yelling "grind 'em till you find 'em"
HTH
The Collin
Aug 22, 2008 08:00 PM
meangreenEG
32
Jun 28, 2007 11:09 PM
t-town_ep
10
Apr 1, 2007 12:41 PM
PhiLG
Sep 20, 2004 08:55 PM
AzntaggeR
Aug 10, 2003 06:38 AM
