anyone using JUN 2 cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel »</TD></TR><TR><TD CLASS="quote">No get the skunk2 stag2 cam's ther like the jun 3cam's</TD></TR></TABLE>
Ok. He posted about JUN 2's, and if anyone has any experience with them or any dyno graphs of them. How does telling him that the S2S2 are similair to the Jun3's and that he should get them help him out? Not everyone wants cams that big. Anyway back on topic. I would also like some input on this, the only info I have heard is that some people use the Jun2 intake cam with a ITR or CTR exhaust cam and that yeilds pretty good results.
I have them in my gsr, they are comparable to Toda Spec A or Sk2 Stg1 cams. I dyno'd at 188whp and 128lbs/tq on a dynapack. I'll post the graphs up whenever I get a chance.
well i have heard that they are a bit better than TODA A and i have toda A and let me tell you that they are awesome so the jun has to be too
https://honda-tech.com/zerothread?id=699674
im pretty sure this car used jun 2's for the header test...read into it.
never dyno'ed the exhaust cam as well - specs are almost identical to the itr exhaust cam so i can't imagine that great of a difference in power - that is why only the intake cam was used
another good thing about the jun type 2 cams - you can use stock itr valve springs/retainers for the cams
Been tested over 2 years ago with no gains to be mentioned. They did however perform better than the Spec As, just been so long most the Dyno charts are MIA. If you wanna spend the extra 300 bucks for half a HP be my guest.
JUN exhaust cam has 10.9mm of lift and 265.3 duration The ITR/CTR has 10.5mm of lift and 235 duration
Modified by hondaboyB16 at 8:04 AM 12/17/2003
