engine wont start..i searched
Old Dec 7, 2003 | 11:46 AM
01IntegraSE's Avatar
Default engine wont start..i searched
ok
its snowing really bad here!! damn snow!
but i had to remove my cold air and put stock air box on! it started up fine to warm up.
i shut it off, poped the hood. Took intake off. Now i got o start and theres a lcicking noise under the dash and a sound comming from the distributor. Doesnt turn over though.
Now it did get wet under the hood, so i dont know
help!
Old Dec 7, 2003 | 11:52 AM
FrostySol's Avatar
Default Re: engine wont start..i searched (90CivicDx)
check for spark, if you've got it it's not the dizzy, if you don't it could be there's a leak in your cap and it got wet. If that's the case you might just need a new cap and rotor. It could also be your coil or ICM though. I'd test them all if you've got time.
Old Dec 7, 2003 | 11:58 AM
Deluzional's Avatar
If its clicking when you try to turn your ignition, that means your battery is dead
Old Dec 7, 2003 | 12:56 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: engine wont start..i searched (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">If its clicking when you try to turn your ignition, that means your battery is dead</TD></TR></TABLE>
Old Dec 8, 2003 | 07:32 AM
but the starter doesnt even engage
Old Dec 8, 2003 | 07:33 AM
blackhatchy's Avatar
Default Re: (90CivicDx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90CivicDx &raquo;</TD></TR><TR><TD CLASS="quote">but the starter doesnt even engage</TD></TR></TABLE>
then your battery is real dead.
Old Dec 8, 2003 | 08:28 AM
Rob!'s Avatar
Default Re: (blackhatchy)
yeah its most likely your battery because they tend to go bad in the cold...and if u dont get spark it should still crank.
bballdude
Oct 3, 2007 05:46 PM
DAcraze
Mar 3, 2006 06:22 PM
REDMAN1322
Sep 1, 2004 03:39 PM
Feriofan
12
Aug 1, 2004 10:28 AM
Nikoli
Mar 10, 2004 12:27 PM
