wheel hop prevention ideas?
Old Dec 6, 2003 | 11:54 PM
HRDCORD's Avatar
Default wheel hop prevention ideas?
So, if you had a 1994 accord and had alot of wheel hop off the launch, what would you do to fix it....?
I was looking into this company called jimfab that makes cross members, but i didnt see any set ups available for my car....
Old Dec 7, 2003 | 06:11 AM
godslayer's Avatar
Default Re: wheel hop prevention ideas? (HRDCORD)
Launch with less RPM......or isthis happening even from a "normal" launch?
Old Dec 7, 2003 | 06:18 AM
HRDCORD's Avatar
Default Re: wheel hop prevention ideas? (godslayer)
This will happen even if i launh at like 2500 rpms.......
Old Dec 7, 2003 | 10:12 AM
HAccord96's Avatar
What kind of suspension setup are you running right now?
Old Dec 7, 2003 | 11:14 AM
godslayer's Avatar
Default Re: wheel hop prevention ideas? (HAccord96)
Sounds like worn shocks to me if you are running stock suspension. If you have lowered springs/stiffer spirings and are running stock shocks they may not provide enough damping forces to prevent the hop you are getting.
Old Dec 7, 2003 | 12:34 PM
97F22B2's Avatar
some better shocks and a big beefy sway bar up front takes care of wheel hop for starters
Old Dec 7, 2003 | 06:45 PM
mildly.interesting's Avatar
Default Re: (97F22B2)
ES motor mount inserts...
Old Dec 7, 2003 | 10:26 PM
HRDCORD's Avatar
I have the Apexi World Sport coilovers right now.... and the energy suspension motor mount inserts.....
Old Dec 7, 2003 | 10:39 PM
HAccord96's Avatar
What tires are you using right now? If a person uses tires with stiff sidewalls, they may experience wheel hop. My friend with azenis has wheel hop and he didn't have it before with his stock tires.
Old Dec 8, 2003 | 02:52 AM
StimpyBoy's Avatar
This probably doesn't help, but I had lots of "wheel hop" before I replaced my clutch. I.e. I had clutch chatter really badly. You're sure it's not the clutch?
Otherwise, I hear that stiffer motor mounts or inserts can reduce wheel hop.
Old Dec 8, 2003 | 03:25 AM
KGAccord's Avatar
Default Re: wheel hop prevention ideas? (StimpyBoy)
also if you are running a low profile tire that contributes to wheel hop, you should be drag racing on 15s.
Old Dec 8, 2003 | 04:32 AM
HRDCORD's Avatar
Well, this weekend when I ran at the track, I was using Azenis.... and they were pretty bald.... but I do experience almost the same when I use the stock tires.
And it shouldn't be the clutch. I have an ACT Full face, with a heavy duty pressure plate. I had it installed the same time as my swap about 5 months ago....
I know that the Azenis probably contributed to the wheel hop, but I'm thinking as far as further prevention beyond tires....
Old Dec 8, 2003 | 06:01 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRDCORD &raquo;</TD></TR><TR><TD CLASS="quote">So, if you had a 1994 accord and had alot of wheel hop off the launch, what would you do to fix it....?
I was looking into this company called jimfab that makes cross members, but i didnt see any set ups available for my car....</TD></TR></TABLE>
I have Tokico Illuminas, race springs, front motor mount insert. I don't notice any wheelhop whatsoever. Those items will work for you. BTW: I squeel my tires on the 1-2 shift nicely with no hop.
Old Dec 8, 2003 | 06:09 AM
v4lu3s's Avatar
RTFM
i would get the motor mouont iinserts it sounds like you goto weak mounts.
and teh reason jimfab doesnt make radis rods for your car is you have them stock.
also lower your tire pressure a LOT
i am able to launch and get great 60 ft times with 215/40/17 tires i jsut have to run at like 16-19 psi.
Old Dec 8, 2003 | 08:54 PM
HRDCORD's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">and teh reason jimfab doesnt make radis rods for your car is you have them stock.</TD></TR></TABLE>
.......Wow, I'm retarded.
Old Dec 8, 2003 | 09:06 PM
azian21485's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97F22B2 &raquo;</TD></TR><TR><TD CLASS="quote">some better shocks and a big beefy sway bar up front takes care of wheel hop for starters</TD></TR></TABLE>
how would a front swaybar prevent wheel hop when he's launching? it's not like he's turning anywhere...
Old Dec 8, 2003 | 11:25 PM
Eddiebx's Avatar
Default Re: (azian21485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">
how would a front swaybar prevent wheel hop when he's launching? it's not like he's turning anywhere...</TD></TR></TABLE>
probably because it's not likely that both tires will hop up at the same time, so when one hops, the other one will be down and the stiffer bar will sort of hold it down some.
Oh yeah and try lowering the pressure alot, I found for them azenis they like about 15-20psi, start off at 20psi and lower from there, but don't go under 15, thats pushing it on the azenis cuz the sidewalls are stiff so they don't fold as well, the tread surface starts to cup.
Old Dec 9, 2003 | 06:38 AM
97F22B2's Avatar
Thank you Eddie
Old Dec 9, 2003 | 07:23 AM
HRDCORD's Avatar
Well I was hoping when I bought the LSD tranny for this car that it might have some effect on my launch..... the sway bars will be coming soon.... i ordered the Suspension Techniques sway bar set 2 weeks ago. After I install it, I'll let you guys know how it works out.
cbstudd77
Suspension & Brakes
Feb 7, 2007 10:58 AM
The Weather Man
Jan 22, 2006 10:07 PM
H22A4Me
Jan 18, 2006 08:51 AM
JDEM1
Dec 30, 2003 11:55 PM
ALF
May 18, 2002 09:29 AM
