tranny prob:can get it out of gear without clutch.
Old Dec 6, 2003 | 11:08 PM
blueeg's Avatar
Default tranny prob:can get it out of gear without clutch.
if im on the gas it wont come out, but if let just let it roll by itself down the road i can get it out of gear. does this in all gear. so what wrong with my tranny?
Old Dec 6, 2003 | 11:15 PM
cxSHOE's Avatar
Default Re: tranny prob:can get it out of gear without clutch. (blueeg)
we need alot more specific information?? start from the begining so we can isolate the problem...
Old Dec 6, 2003 | 11:16 PM
clm's Avatar
clm
Default Re: tranny prob:can get it out of gear without clutch. (cxSHOE)
Nothing is wrong; that's the way the transmission works.
Old Dec 6, 2003 | 11:31 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueeg &raquo;</TD></TR><TR><TD CLASS="quote">if im on the gas it wont come out, but if let just let it roll by itself down the road i can get it out of gear. does this in all gear. so what wrong with my tranny?</TD></TR></TABLE>
Try to step on the clutch pedal!!! not the gas pedal!!
clutch pedal=shifting or get out of gear
gas pedal=accelerating or going faster
Old Dec 7, 2003 | 01:46 AM
mh's Avatar
mh
Default Re: tranny prob:can get it out of gear without clutch. (HATCHingMN)
there is nothing wrong with our tranny. you can pull it out of gear as long as there is no load on it. and you can pull it out when you are accelerating as well, just have to pull harder.
Old Dec 7, 2003 | 02:55 AM
blackhatchy's Avatar
Default Re: tranny prob:can get it out of gear without clutch. (mh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mh &raquo;</TD></TR><TR><TD CLASS="quote">there is nothing wrong with our tranny. you can pull it out of gear as long as there is no load on it. and you can pull it out when you are accelerating as well, just have to pull harder. </TD></TR></TABLE>
what he says, nuttin wrong
Old Dec 7, 2003 | 03:54 AM
JDMlyfestyle's Avatar
you can shift gears in your car without the clutch between 3500-3800 RPM's i dont recommed that route id prefer a clutch
Old Dec 7, 2003 | 04:00 AM
GsR HtCh's Avatar
There is nothing wrong with your tranny. that is normal. have you ever driven a 5 speed before. Thats what they do. There is no load so its easier. Try doing it at 8000 rpms though.
Old Dec 7, 2003 | 05:20 PM
joecivic93's Avatar
Default Re: tranny prob:can get it out of gear without clutch. (GsR HtCh)
the clutch is really only needed for starting/stopping but is recommended to use all the time for your trans sake! If shifter were popping out under acceleration then you would have need for concern.
Old Dec 7, 2003 | 05:49 PM
E-Rok's Avatar
EPIC TUNING
Default Re: tranny prob:can get it out of gear without clutch. (joecivic93)
yea you can pull it out usually when off the gas, hell I can throw mine in some gears without a clutch at the right RPM's
charmin1213
Sep 19, 2008 10:32 PM
xxmastermindxx
Sep 21, 2006 08:32 PM
edunnett
10
Sep 10, 2004 09:32 AM
2000si
Sep 24, 2003 02:39 PM
Brandon
Jul 31, 2002 09:59 PM
