Engine question
wasup people i was just wondering i just bought a 1995hatch civic si and i am going for an engine swap can anyone tell me if a jdm gsr type-r engine will fit? and if it can't can you tell me the best engine for my civic the one that gives out most power (money aint a problem ) thanx it would be appreaciated the most
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
2. Yes money is a problem. If it was, you wouldn't be driving a civic.</TD></TR></TABLE>
ill disagree. nothing is wrong with driving a civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC1995 »</TD></TR><TR><TD CLASS="quote">ok thanx i thought so but i wasnt too sure because i havent seen anyone put a 200hp engine in a civic 1995 si hatch</TD></TR></TABLE>
ahhhh man that almost like a factory option around this site. ive got one in my civic excpet its an EK, b81c5 baby!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC1995 »</TD></TR><TR><TD CLASS="quote">tnx ppl for the info</TD></TR></TABLE>
thank God you are done posting for the day. now all you can do is search which is what you should have done in the first place. Click on the FAQ's at the top of the forum and look around. All your answers are there.
EDIT:
Full Name: jasmin
If you are 14 where do you get your money from??
EDIT:
Full Name: jasmin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">1. There is no such thing as a jdm gsr type-r engine
I have heard the Type-R motor referred to as the B18C type R....unless that is totally flawed....Ima do a search...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh »</TD></TR><TR><TD CLASS="quote">
EDIT:
Full Name: jasmin
He is a DEALER yO....he has mad BLING BLING.....GIMME THREE OF EACH....
EDIT:
Full Name: jasmin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">
I have heard the Type-R motor referred to as the B18C type R....unless that is totally flawed....Ima do a search...</TD></TR></TABLE>
That is cooorrrect.(takes off shirt slowly/seductively)
That is cooorrrect.(takes off shirt slowly/seductively)</TD></TR></TABLE>
You're weird man.... http://www.j-garage.com/1201.htm
Its in there....
Its in there....
there is no such thing as a jdm b18c5/c1, however, that doesnt mean there is a such thing as a jdm gsr type r motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 »</TD></TR><TR><TD CLASS="quote">
there is no such thing as a jdm b18c5/c1, however, that doesnt mean there is a such thing as a jdm gsr type r motor.</TD></TR></TABLE>
Ok....I guess its just "in the wording"....
Its in there....</TD></TR></TABLE>
weird how man. explain that.
You do not find this weird............................................. .......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh »</TD></TR><TR><TD CLASS="quote">Didnt you ever see Billy Madison you fool. Two words...Chris Farley</TD></TR></TABLE>
Damnit....man...I just woke up and you expect me to be full of wit?? YOU CRAZY...
oh well
</TD></TR></TABLE>oh well
ok *******.... the B18C in japan is 2 different engines. the JDM "GS-R" is the B18C that comes in the Integra SiR-G (no GS-R in japan). It's a P72 engine that is very similar to our B18C1.
the JDM B18C "Type-R" engine is what comes in the JDM Integra Type-Rs. it's a PR3 engine that is very similar to our Integra Type-R engine, but, since there are no sub-codes in JDM engines (as in B18C(1) or B18C(5), they are both called the B18C, even though they are different engines.
The SiR-G engine (or GS-R) is referred to as the B18C Spec-G, and the JDM ITR (Integra Type-R) engine is referred to as the B18C Spec-R. hope this helps you fellas a little bit.
-Shawn
-Shawn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">ok *******.... the B18C in japan is 2 different engines. the JDM "GS-R" is the B18C that comes in the Integra SiR-G (no GS-R in japan). It's a P72 engine that is very similar to our B18C1.
the JDM B18C "Type-R" engine is what comes in the JDM Integra Type-Rs. it's a PR3 engine that is very similar to our Integre Type-R engine, but, since there are no sub-codes (as in B18C(1) or B18C(5), they are both called the B18C, even though they are different engines.
the SiR-G engine (or GS-R) is referred to as the B18C Spec-G, and the JDM ITR (Integra Type-R) engine is referred to as the B18C Spec_R. hope this helps you fewllas a little bit.
-Shawn</TD></TR></TABLE>
Thank you...I knew I was right somewhere.....
