map sensor on itr manifold
Old Sep 18, 2001 | 11:59 AM
rainforest's Avatar
Default map sensor on itr manifold
ok I have a first gen b16a head and was wondering were do i mount a map sensor on a itr intake manifold. Being that obd1/2 b series motors have the map sensor on the tb. any help would be apprecative
Old Sep 18, 2001 | 12:38 PM
3rdShift.org's Avatar
New User
Default Re: map sensor on itr manifold (rainforest)
What TB are you using and what is your reason for not mounting it in the stock location?
Old Sep 18, 2001 | 06:34 PM
rainforest's Avatar
Default Re: map sensor on itr manifold (3rdShift.org)
shut up rich
Old Sep 18, 2001 | 07:06 PM
B18C-EJ1
Guest
Posts: n/a
You need to use the 94+ integra t-body where the map sensor sits on top of the t-body. If you use the older 90-93 style, you'll need to run a hose to the map sensor.
Either way, you need the newer style map sensor.
Old Sep 18, 2001 | 08:19 PM
rainforest's Avatar
Default Re: map sensor on itr manifold (B18C-EJ1)
thats what i though
thanks i needed reassurance
Old Sep 19, 2001 | 02:38 AM
rainforest's Avatar
so what ia have to do if i don't find a obd1/2 tb then i need a obd1/2 map sensor and just mount it anywhere if it is connected to the tb.
Old Sep 19, 2001 | 03:56 AM
Davep's Avatar
If you use the 1st gen b16 TB you won't have the fast idle valve because it's on the 1st gen intake manifold. So most people use a OBD 1 TB from a GSR or B16 that has the fast idle valve in on the TB. For the MAP sensor you can use either one, they are all the same just one is on the firewall and one is on the TB. If you use the OBD 1 TB just extend the MAP plug up and use the one on the TB.
You need the OBD 1 TB gasket too.
zapzach
Apr 30, 2013 09:45 AM
T-nastyteggy
Apr 20, 2011 08:37 PM
bodiez
Oct 26, 2010 02:17 PM
grant97teg
Apr 20, 2009 06:47 AM
B16A CRX
Jul 9, 2007 06:14 PM
