B16a w/ JUN IIIs - what pistons?
Old Dec 6, 2003 | 01:28 PM
MuJun's Avatar
Default B16a w/ JUN IIIs - what pistons?
Hi
What sort of pistons would people suggest that would work well with the JUN IIIs? Thinking along the lines of CTR oversized, this giving roughly 11.1:1 cr. What other options could i think about?
Thanks
Old Dec 6, 2003 | 01:37 PM
ispkarl's Avatar
Default Re: B16a w/ JUN IIIs - what pistons? (MuJun)
the bigger in size and compression, the more power those cams will make
Old Dec 6, 2003 | 02:10 PM
MuJun's Avatar
Default Re: B16a w/ JUN IIIs - what pistons? (ispkarl)
Whats the max cr i could goto whilst keeping it a good daily driver?
Old Dec 6, 2003 | 02:25 PM
Unsung's Avatar
My buddy ran Jun III's, GSR head, B16a block, CTR pistons... put down 170whp on a MUSTANG dyno... that's good for 185-190 on a Dynojet.
Old Dec 6, 2003 | 03:02 PM
hotintegranights's Avatar
Default Re: B16a w/ JUN IIIs - what pistons? (Unsung EM1)
11:1:1 comp is good for jun 3's but not good enough i would say try to at least go with 12:1 comp or higher that is if you have 93,94 gas in your area remember these cams love highcompression.
also by the way ctr os pistons will give you a 10:8:1 comp unless you opt for the 2 layer head gasket which will be just about 11:1:1
Old Dec 6, 2003 | 06:00 PM
MuJun's Avatar
Default Re: B16a w/ JUN IIIs - what pistons? (hotintegranights)
I thought they would give me 11.1:1 because of the b16a's shorter deck height?
What sorta pistons am i looking at to give me 12:1 cr? Im not wanting to sleeve the block or anything.
Old Dec 7, 2003 | 04:11 AM
MuJun's Avatar
Anyone?
Old Dec 7, 2003 | 07:21 AM
yeah it gives you 10:8 cause of the b16 deck. if you had the b18 block with your b16 crank with 81.25mm ctr pistons then you would get 10:5:1.
if you want 12:1 on your b16 you can go with some aftermarket pistons like je,wiseco.
Old Dec 7, 2003 | 10:42 AM
99-DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MuJun &raquo;</TD></TR><TR><TD CLASS="quote">I thought they would give me 11.1:1 because of the b16a's shorter deck height?
What sorta pistons am i looking at to give me 12:1 cr? Im not wanting to sleeve the block or anything.</TD></TR></TABLE>
Yes, it will give you higher compression because b16a's have a shorter deck height than the b16b... the b16b block is an ITR block...
Old Dec 7, 2003 | 10:47 AM
GreenR's Avatar
oversized CTR or custom JE 12:1
Old Dec 7, 2003 | 11:25 AM
99-DC2's Avatar
oh i'm talking about CTR oversized where instead of 10.8 as normally quoted they will be higher, like 11.1, on the b16a block as opposed to the b16b...
Old Dec 7, 2003 | 02:03 PM
MuJun's Avatar
Default Re: (DC2-99)
Ive seen a few pistons which are 81.5mm, would you be able to bore the .5mm from the std b16a block without resorting to sleeves?
Modified by MuJun at 11:40 PM 12/7/2003
Old Dec 7, 2003 | 03:02 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsung EM1 &raquo;</TD></TR><TR><TD CLASS="quote">My buddy ran Jun III's, GSR head, B16a block, CTR pistons... put down 170whp on a MUSTANG dyno... that's good for 185-190 on a Dynojet. </TD></TR></TABLE>
Do you know what the cam gear settings were?
pythoner
Mar 22, 2007 05:30 PM
rig9896
Mar 29, 2004 03:52 PM
frostwhite_92
Mar 28, 2004 12:30 AM
egchan
Feb 27, 2003 12:30 PM
RJL
Sep 18, 2001 05:10 PM
