Click noise when i accelerate. is it the axels?
Old Dec 6, 2003 | 12:13 PM
Unjockable's Avatar
New User
Default Click noise when i accelerate. is it the axels?
when i accelerate, sometimes there's a "click" on my passenger side. there's only one "click." what could it be? doesn't happen when i turn.
Old Dec 6, 2003 | 12:17 PM
Trial User's Avatar
Default Re: Click noise when i accelerate. is it the axels? (Unjockable)
Could be the CV's beggining to go. Maybe something is loose?
Old Dec 6, 2003 | 12:26 PM
Unjockable's Avatar
New User
Default Re: Click noise when i accelerate. is it the axels? (Trial User)
how can i make sure that it's the cv boot about to go? anything i should look for when i go under there?
Old Dec 6, 2003 | 01:09 PM
blackeg's Avatar
check and see if the cv boot is ripped. once it rips grease gets out and dirt gets in, accelerating the go-bad process. check all your other stuff for tightness(tierods,axle itself,swaybar....) does it click when u accelerate in a straight line, or only around turns???
Old Dec 6, 2003 | 01:37 PM
Unjockable's Avatar
New User
Default Re: Click noise when i accelerate. is it the axels? (blackeg)
only when i'm going straight. doesn't click when i turn.
Old Dec 6, 2003 | 02:03 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable &raquo;</TD></TR><TR><TD CLASS="quote">when i accelerate, sometimes there's a "click" on my passenger side. there's only one "click." what could it be? doesn't happen when i turn. </TD></TR></TABLE>
Does it do it going forward just after moving in reverse?
Old Dec 6, 2003 | 02:24 PM
Unjockable's Avatar
New User
Default Re: Click noise when i accelerate. is it the axels? (Chiovnidca)
no reverse. just straight forward on the streets.
Old Dec 6, 2003 | 03:43 PM
EG2 SiR's Avatar
check the A/C vibration mount... if the bolt isn't tight enough, under torque the metal center of the mount gets shifted and makes a big click sound.. . .. at least, that's what happened to me.
Old Dec 6, 2003 | 03:51 PM
96_CX's Avatar
Default Re: Click noise when i accelerate. is it the axels? (EG2 SiR)
yeah my car does the same thing, but mine clicks multiple times.... ....i've always wondered where that noise came from....i guess now i know where to look...thanks!!!
Old Dec 6, 2003 | 03:56 PM
Unjockable's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">check the A/C vibration mount... if the bolt isn't tight enough, under torque the metal center of the mount gets shifted and makes a big click sound.. . .. at least, that's what happened to me.
i have no AC. no AC mounts or brackets on the block either.
Old Dec 6, 2003 | 04:10 PM
RC_SKUBY's Avatar
damn that noise is annoying. had to put up with that in my old car. Its more then likely the cv joints thats what it turned out to be in mine atleast.
EG2 SiR's Avatar
MY THEORY &lt;~~~flying right out the door.
Old Dec 6, 2003 | 04:15 PM
Unjockable's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">MY THEORY &lt;~~~flying right out the door.</TD></TR></TABLE>
LOL.
what's the price on changing the CV boot? would it be better if i just swap out the axel/boot?
Old Dec 6, 2003 | 04:22 PM
EG2 SiR's Avatar
LOL.
what's the price on changing the CV boot? would it be better if i just swap out the axel/boot? </TD></TR></TABLE>
if it's the inner it's about 8-10bux. If it's the outer, double it cause you'll have to get by the inner to get to the outer. If the axle is in decent shape, it is worth the time and money (not to mention mess) if it's a pretty beat axle... a rebuilt shouldn't cost more than $65-$70
Old Dec 6, 2003 | 04:26 PM
Unjockable's Avatar
New User
since you're in socal, where can you get it done for that price? anywhere?
Old Dec 6, 2003 | 04:30 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable &raquo;</TD></TR><TR><TD CLASS="quote">since you're in socal, where can you get it done for that price? anywhere? </TD></TR></TABLE>
oh. that's just parts.... I can do it for $50 parts and labor to rebuild your axle. or $100 parts and labor for a new one.
Old Dec 6, 2003 | 04:33 PM
GsR HtCh's Avatar
id put money on it being the CV joints
Old Dec 6, 2003 | 04:34 PM
Unjockable's Avatar
New User
oh. that's just parts.... I can do it for $50 parts and labor to rebuild your axle. or $100 parts and labor for a new one.</TD></TR></TABLE>
i don't think anything is wrong with my axels since i just got it rebuilt.
Old Dec 6, 2003 | 07:37 PM
blackeg's Avatar
Default Re: Click noise when i accelerate. is it the axels? (1993sir)
if it turns out to be the cv joint is bad- just get a new axle. go to autozone and get the 70 dollar one with lifetime warranty. trust me- it felt soo good to get free axle when mine broke
SpoolFedEF
10
Jan 4, 2006 07:19 AM
lowRIDAH
10
Nov 18, 2004 06:18 AM
Miller Time
Jun 15, 2003 02:19 PM
bwan24
May 25, 2003 01:07 PM
