Every one Please Help !! Check Engine Light On After VAFC II Installed.
Old Dec 6, 2003 | 11:05 AM
brian2903's Avatar
Default Every one Please Help !! Check Engine Light On After VAFC II Installed.
My car's check engine light is on after installed VAFC II last night. I'm sure the wiring is correct(Checked for mroe than 3 times); however, there's no more VTec kick in singal from ECU anymore, which mean if I don't set the VAFC Vtec kick in point, the car won't have Vtec kick in.
I suspect the connection of my original vtec wire to ECU is lost. If so, would that make the check engine light on? Are there any other reasons that would block the ECu Vtec kick in singal.
Old Dec 6, 2003 | 02:28 PM
KGAccord's Avatar
Default Re: Every one Please Help !! Check Engine Light On After VAFC II Installed. (brian2903)
I would connect back all the major wires except the ones that are just spliced and reread the wiring diagrams. is the VAFC II approved for the 94-97 Accord? i know the original VAFC wasn't and many people including me had problems.
Old Dec 6, 2003 | 06:27 PM
brian2903's Avatar
Mine is an Accord with H22A engine and ECU. So, I don't think it's the problem of Accord.
Old Dec 6, 2003 | 09:42 PM
brian2903's Avatar
One more thing I just find out today, the rev Limited drop down to 6480rpm instead of the stock 7000rpm.
Old Dec 7, 2003 | 09:51 AM
brian2903's Avatar
bump
Old Dec 7, 2003 | 11:38 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian2903 &raquo;</TD></TR><TR><TD CLASS="quote">My car's check engine light is on </TD></TR></TABLE>
Whay year and model? What code does it have stored?
Old Dec 7, 2003 | 06:10 PM
brian2903's Avatar
Mine is H22A Engine with OBD1 ECU, the check engine light code is two long and 1 short.
Old Dec 7, 2003 | 06:59 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian2903 &raquo;</TD></TR><TR><TD CLASS="quote">Mine is H22A Engine with OBD1 ECU, the check engine light code is two long and 1 short.</TD></TR></TABLE>
Code 21. Have you checked the VTEC solenoid and it's wire?
Old Dec 7, 2003 | 08:35 PM
brian2903's Avatar
I jsut found that the Vtec wire is lost from the harness..and I don't know how to maybe it re-connect back.. Is honda possible to fix it?
Old Dec 7, 2003 | 08:37 PM
brian2903's Avatar
BTW, what does code 21 means?
Old Dec 9, 2003 | 02:23 PM
brian2903's Avatar
bump
Old Dec 9, 2003 | 03:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian2903 &raquo;</TD></TR><TR><TD CLASS="quote">BTW, what does code 21 means?</TD></TR></TABLE>
A problem with the VTEC solenoid or wiring. So you found your problem, huh?
Old Dec 11, 2003 | 03:10 PM
brian2903's Avatar
And I brought my car to Honda today, they help me to put the lossing Vtec wire back to the ECU. They said the check engine light goes off right after they did that; however, when they go test drive the car the engine light comes on again.
Anyways, still no Vtec from the stock ECU
Old Dec 11, 2003 | 05:20 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian2903 &raquo;</TD></TR><TR><TD CLASS="quote">And I brought my car to Honda today, they help me to put the lossing Vtec wire back to the ECU. They said the check engine light goes off right after they did that; however, when they go test drive the car the engine light comes on again.
Anyways, still no Vtec from the stock ECU</TD></TR></TABLE>
What code does it have stored now?
Old Dec 11, 2003 | 06:24 PM
brian2903's Avatar
Default Re: Every one Please Help !! Check Engine Light On After VAFC II Installed. (Chiovnidca)
honda stay it's still the vtec code.
code 21..........
VTEC_PRODUCTION
Mar 25, 2007 12:39 PM
Freshazzburu
Feb 14, 2005 06:19 AM
sagron69
11
Mar 19, 2004 06:51 PM
brian2903
Dec 11, 2003 07:20 PM
brian2903
Dec 11, 2003 06:25 PM
