Every one Please Help !! Check Engine Light On After VAFC II Installed.
Old Dec 6, 2003 | 11:01 AM
brian2903's Avatar
Default Every one Please Help !! Check Engine Light On After VAFC II Installed.
My car's check engine light is on after installed VAFC II last night. I'm sure the wiring is correct(Checked for mroe than 3 times); however, there's no more VTec kick in singal from ECU anymore, which mean if I don't set the VAFC Vtec kick in point, the car won't have Vtec kick in.
I suspect the connection of my original vtec wire to ECU is lost. If so, would that make the check engine light on? Are there any other reasons that would block the ECu Vtec kick in singal.
Old Dec 6, 2003 | 12:24 PM
speedracer9k's Avatar
after you installed it, did you set the initial settings before you started the car or did you just start the car and run it into VTEC?
Old Dec 6, 2003 | 01:30 PM
H22A EG6's Avatar
Default Re: (speedracer9k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer9k &raquo;</TD></TR><TR><TD CLASS="quote">after you installed it, did you set the initial settings before you started the car or did you just start the car and run it into VTEC?</TD></TR></TABLE>
Old Dec 6, 2003 | 02:32 PM
Shakes's Avatar
space cadet
Default Re: Every one Please Help !! Check Engine Light On After VAFC II Installed. (brian2903)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian2903 &raquo;</TD></TR><TR><TD CLASS="quote">My car's check engine light is on after installed VAFC II last night. I'm sure the wiring is correct(Checked for mroe than 3 times); however, there's no more VTec kick in singal from ECU anymore, which mean if I don't set the VAFC Vtec kick in point, the car won't have Vtec kick in.
I suspect the connection of my original vtec wire to ECU is lost. If so, would that make the check engine light on? Are there any other reasons that would block the ECu Vtec kick in singal.</TD></TR></TABLE>
did you use the POS connectors that they supply with it or did you do it properly and solder them?
if you used the connectors i would remove those and solder them (i suspect you dont know how since you didnt do it in the first place) so find someone who can solder and do it right.
if you soldered it, check your wiring. check your solder joints, make sure that there are no burn marks on either the solder or the wiring. pull on the connections as well. if they break off then you had a "cold" solder joint and that is bad.
Doug
Old Dec 6, 2003 | 06:30 PM
brian2903's Avatar
I did the initial set up before I start the engine and I didn't use the connector which they provide.
However, I'd like to do the initial set up again, what should I do in order to reset the VAFC?
Old Dec 6, 2003 | 08:37 PM
not sure exactly how to reset the VAFC, but just try to set it to the intitial settings first and see if it changes anything
Old Dec 6, 2003 | 09:42 PM
brian2903's Avatar
I did set it to initial again, but nothing happened.
By the way, the rev Limited drop down to 6480rpm instead of the stock 7000rpm.
Old Dec 7, 2003 | 09:59 AM
brian2903's Avatar
bump
Old Dec 7, 2003 | 10:08 AM
satan_srv's Avatar
What code is it? That would help narrow it down.
Old Dec 7, 2003 | 06:10 PM
brian2903's Avatar
The code is 2 long 1 short
Old Dec 7, 2003 | 11:02 PM
HKSpowers's Avatar
Did you try resetting the ECU and clearing it?
That might help. ;0)
Old Dec 8, 2003 | 05:23 AM
brian2903's Avatar
Yes, I do. I unplug the battery for 15 mins to reset the ECU
But, do we have other way to reset the ECU?
Old Dec 9, 2003 | 02:22 PM
brian2903's Avatar
I reseted the EUC by takle out the fuse of ECU; however, it doesn't help
Old Dec 9, 2003 | 08:06 PM
Hondaaccordvtec's Avatar
Code 21 - Variable Valve Timing & Valve Lift Electronic Control (Vtec) Solenoid Valve.
Check you electrical connection at the solenoid. Also, look at ALL fuses and make sure non are blown. Reset the ECU - to really know for 100% sure that the ECU was reset - I usually remove the connectors on the ECU itself.
Start car, wait for normal operating temp. and go drive and get into the Vtec range and if you still ge the CEL.
Old Dec 9, 2003 | 08:37 PM
brian2903's Avatar
Do anyone know how exactly connect the VTM wire?
Old Dec 11, 2003 | 03:10 PM
brian2903's Avatar
And I brought my car to Honda today, they help me to put the lossing Vtec wire back to the ECU. They said the check engine light goes off right after they did that; however, when they go test drive the car the engine light comes on again.
Anyways, still no Vtec from the stock ECU.
Old Dec 11, 2003 | 06:25 PM
brian2903's Avatar
bump
B18c1vicrx
Apr 13, 2008 12:36 PM
sagron69
11
Mar 19, 2004 06:51 PM
brian2903
Dec 11, 2003 07:20 PM
brian2903
Dec 11, 2003 06:24 PM
Renegade
Feb 13, 2002 12:08 PM
