OBD 1 or 2
Old Dec 6, 2003 | 04:33 AM
sapper69's Avatar
Default OBD 1 or 2
Allright, I tried searching,and I'm sure this has been asked 1000's of times,but can I make a p13 obd1 h22a work right inmy obd2 97 accord ex, or do any of you know where to get a good obd2 h22a for around the same price? I wouldlike to stick with the obd2 to keep it easy. But availability might decide different. Thanks.
Old Dec 6, 2003 | 04:57 AM
HAccord96's Avatar
Default Re: OBD 1 or 2 (sapper69)
You could install an OBD1 H22 motor work in your OBD2 car if you have a jumper harness (obd2-obd1) for the p13 ecu. You could use the obd2 ecu from the Accord, but it would run like total crap. It is only around 75 dollars nowadays to get a jumper harness anyways.
Old Dec 6, 2003 | 10:25 AM
Nick H's Avatar
New User
Default Re: OBD 1 or 2 (HAccord96)
if you can, stick with obd2...it will make the swap much easier...trust me, i went the obd1 route...major pain the ***...HMO has obd2 h22's sometimes...also, check ebay...sometimes you will see one in the classifieds of this site...
Old Dec 6, 2003 | 12:30 PM
adio's Avatar
Default Re: OBD 1 or 2 (Nick H)
i converted an obdII motor to obdI, no problems.
allen8908
Mar 26, 2009 04:03 PM
rollercosta123
Oct 19, 2006 11:11 PM
akoreanyoungsta
Jul 8, 2006 06:22 PM
duceducecord
Jul 1, 2006 09:27 AM
KStuned
Jan 14, 2002 03:20 PM
