mugen-ecu=obd1 right?
Old Sep 18, 2001 | 08:27 AM
mugenr#1011's Avatar
Default mugen-ecu=obd1 right?
the ecu converts over to obd1 right? so that means i can run a spoon cat jack with no check engine light? is that ecu legal for street use? also some info from anyone using this setup would be greatly appreciated! like how is the gas mileage? and do you like the way it works. anyone using the jdm mugen header? thanks.....mugen
Old Sep 18, 2001 | 08:56 AM
ZygSpeed's Avatar
Default Re: mugen-ecu=obd1 right? (mugenr#1011)
There's a sticker on the ECU that says it's for RACING USE ONLY !
And, you won't pass emissions even with only and AEM and Muffler.
Ask me how I know!
Somewhere in Northern Virginia.
Old Sep 18, 2001 | 09:08 AM
Default Re: mugen-ecu=obd1 right? (zygspeed)
well here in florida they got rid of emmisions. so we dont really worry about that. i did know it said RACING USE ONLY but who is gonna know i have it!! the test pipe is the only concern
Old Sep 18, 2001 | 09:37 AM
ZygSpeed's Avatar
It won't trip the EIC (engine check light) .
P.S. You might also want to get an AEM FPR (or some other), since it seems to run really lean otherwise.
Might want to up the fuel pressure to the 56-60 psi range (and check it with a dyno run or two and wideband O2).
[Modified by zygspeed, 1:39 PM 9/18/2001]
Old Sep 18, 2001 | 09:41 AM
Mike M's Avatar
Founding Member
The ecu is made for Japanese cars which are OBD1 Even though they have the same ECU Plugs as our 96-99 OBD2.
So the ECU is OBD1
Old Sep 18, 2001 | 10:34 AM
BoM's Avatar
BoM
Default Re: mugen-ecu=obd1 right? (TypeRmsm)
what does the ecu do?
what increase would it do to a stock R?
Old Sep 18, 2001 | 10:35 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: mugen-ecu=obd1 right? (bommiE)
457 posts, and you don't know what an ECU does???
Jbur074
Nov 30, 2007 11:50 AM
Bimmerman
Sep 5, 2005 07:00 AM
groovyeshua
18
Dec 18, 2002 11:19 PM
phatcivic99
Jun 20, 2002 01:53 PM
