Rear washer camber corection????
Old Dec 5, 2003 | 03:49 PM
spencedogg's Avatar
Default Rear washer camber corection????
How much can washers on the rear correct the rear camber? I have a -1.2 and -1.3 on the rear i found out today can i corect this with washers?
Thanks
Spencer
Old Dec 5, 2003 | 03:58 PM
GsR HtCh's Avatar
Default Re: Rear washer camber corection???? (spencedogg)
yes you can. i used 3 but i dont know how much camber i had
Old Dec 5, 2003 | 04:42 PM
-Gambit-'s Avatar
Default Re: Rear washer camber corection???? (GsR HtCh)
yes washers will fix that camber problem, but the amount of washers needed depends on how thick the washers are. You have to go by trial and error
Old Dec 5, 2003 | 05:00 PM
domoMKIV's Avatar
Default Re: Rear washer camber corection???? (Evil_gambit33)
if youre going with more than 2 washers a bolt.......you might want to look into longer bolts just to be on the safe side.......
i used 2 washers per oem bolt and it was fine......but that was like 2yrs ago so i dont really remember how fine it was.
Old Dec 5, 2003 | 05:26 PM
spencedogg's Avatar
up
Old Dec 5, 2003 | 06:13 PM
-Trinitron-'s Avatar
Anybody got any pics of this? I was wondering about it as well.
Old Dec 5, 2003 | 07:40 PM
kommon_sense's Avatar
Default Re: Rear washer camber corection???? (-TRINiTRON-)
with -1.2 and -1.3, I don't know that I would even bother. I think that my rear camber is about -1.3 *AFTER* I put the washers in Been that way for a year and a half.
Old Dec 5, 2003 | 08:00 PM
00EM1Si's Avatar
Default Re: Rear washer camber corection???? (kommon_sense)
i went hardcore and put 4 washers
Old Dec 5, 2003 | 08:17 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spencedogg &raquo;</TD></TR><TR><TD CLASS="quote">-1.2 and -1.3 on the rear</TD></TR></TABLE>
damn that's almost stock camber. i wouldn't even worry about that ****. but if you are, search for washer trick, i've read some things about it, but have forgotten everything. i vaguely remember something 2 washers for every degree - but that depends on the thickness of course.
Old Dec 5, 2003 | 08:19 PM
Chris y0!'s Avatar
factory specs for an EK:
front:
min: -1 degree
max: 1 degree
rear:
min: -2 degree
max: 0 degree
Old Dec 6, 2003 | 02:01 AM
Mr. Choi's Avatar
New User
Default Re: Rear washer camber corection???? (Krazipeenoi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krazipeenoi &raquo;</TD></TR><TR><TD CLASS="quote">i went hardcore and put 4 washers</TD></TR></TABLE>
i have 5 hardened washers. there is nothing hardcore about it.
Old Dec 6, 2003 | 04:37 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Rear washer camber corection???? (Mr. Choi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi &raquo;</TD></TR><TR><TD CLASS="quote">
i have 5 hardened washers. there is nothing hardcore about it.</TD></TR></TABLE>
hardcore? lol... i have no washers and -3 degrees
Old Dec 6, 2003 | 05:42 AM
mildly.interesting's Avatar
bwahahahahaha
Old Dec 6, 2003 | 07:34 AM
PSU's Avatar
PSU
formerly DxHatchback
i used longer screws and three washers per screw
Old Dec 7, 2003 | 01:14 AM
00EM1Si's Avatar
5 is too many.....u have no camber now?...you have to have atleast some camber..if not.... u can't handle worth ****.
revolt_allmotor
Suspension & Brakes
Nov 6, 2005 09:04 PM
Valvola
Sep 10, 2005 08:45 AM
Wazup
Suspension & Brakes
Apr 29, 2005 08:10 PM
Kid1320
23
Feb 12, 2003 10:01 PM
FourthGenHatch
11
Oct 1, 2002 07:00 PM
