h22 guys.
It works....
I dont know. Either way its the same. I could car less cause I know my car is tuned well, and I dont have to worry about knocking. Even if you use the p72 & hook up the butterflies in the intake it wont work right cause it comes on too late for the H22 which would kill vtec some...
If I could get a p30 (del sol dohc vtec) then I would. Just to have the knock, but I couldnt get one for a steal. So **** it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr »</TD></TR><TR><TD CLASS="quote"> Even if you use the p72 & hook up the butterflies in the intake it wont work right cause it comes on too late for the H22 which would kill vtec some...
more info on this
more info on this
I cant remember exactly, but I know that the butterflies wont open at the right time anyway. So its gonna mess with vtec changeover & everything.
Just save some money & get the p28
No the p28 has nothing to control the IAB.
IMO the IAB's are over-rated. If you really think about it. When you race someone your gonna launch at like what 4000 or so. The IAB's will be about ready to open then anyway. So I would just take them out & not worry about it, or hook up a vacuum line to the iab control, and leave it alone. That way it would open at WOT.
P28 w/S200 setup. Running modified Type S settings and it runs great. No IAB settings on it but we removed the butterfly stack from the intake manifold so top end power feels really good. I've given a couple of other HT members the same program that I'm running and they said they like it alot on their H22A Civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by se93 »</TD></TR><TR><TD CLASS="quote">Dave:
Check your email.</TD></TR></TABLE>
Gotcha back
Gotcha back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">P28 w/S200 setup. Running modified Type S settings and it runs great. No IAB settings on it but we removed the butterfly stack from the intake manifold so top end power feels really good. I've given a couple of other HT members the same program that I'm running and they said they like it alot on their H22A Civics.</TD></TR></TABLE>
can you give me more info on the removal of the iab's? are you a hondata dealer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr »</TD></TR><TR><TD CLASS="quote">P28
dont u lose torque when u take the buterflys out i think u do cause my friend has a gsr and he took them out and he said that it feels like it has less torque im not sure if its the same on h22 as it is with gsr
[QUOTE=slamed93si]dont u lose torque when u take the buterflys out i think u do cause my friend has a gsr and he took them out and he said that it feels like it has less torque im not sure if its the same on h22 as it is with gsr
[/QUOTE
that may be good for me
[/QUOTEthat may be good for me
I recall looking at a dyno chart somewhere that with the p72 you will lose some bottom end power but gain top end power. And with the p28 will have more bottom end power but lose a little power up top compared to the p72.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">I recall looking at a dyno chart somewhere that with the p72 you will lose some bottom end power but gain top end power. And with the p28 will have more bottom end power but lose a little power up top compared to the p72.</TD></TR></TABLE>
yea thats what im thinking. i have pleanty of bottom end power. maybee ill get both! lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr »</TD></TR><TR><TD CLASS="quote">how often do you race below 4k rpm? It wont even matter. From what I understand its like 3ft/lbs of torque lost. You wont even notice.
im going to try it with the line disconnected and see how it feels.(daily driveability)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 »</TD></TR><TR><TD CLASS="quote">
can you give me more info on the removal of the iab's? are you a hondata dealer?</TD></TR></TABLE>
Just take apart the intake manifold and remove the butteryfly stack and put it back together. Better for top end performance. Not an official Hondata dealer but I have a Stage 4B and have all of the stock base programs from the CD (older version) and can load those and modify them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamed93si »</TD></TR><TR><TD CLASS="quote">dont u lose torque when u take the buterflys out i think u do cause my friend has a gsr and he took them out and he said that it feels like it has less torque im not sure if its the same on h22 as it is with gsr
Sure, you lose some low end torque, but on a H22A motor in a lighter Civic chassis, it's almost negligible and not even noticable. Maybe so on a 1.8L but not on the 2.2
</TD></TR></TABLE>Sure, you lose some low end torque, but on a H22A motor in a lighter Civic chassis, it's almost negligible and not even noticable. Maybe so on a 1.8L but not on the 2.2
