Metal Shop Project Ideas
Old Dec 5, 2003 | 11:22 AM
DIYaccord's Avatar
Default Metal Shop Project Ideas
Hey, anybody have any ideas on what to build in metal shop. it's my second year in high school shop (senior now) and need some projects to get me through the year
so far my ideas are:
Strut Bars
c-pillar brace
chassis stiffeners generally
Old Dec 5, 2003 | 12:05 PM
.bagged's Avatar
Default Re: Metal Shop Project Ideas (DIYaccord)
build some plates for shaving door handles, or take a tie rod a re-fabricate it shorter for some sort of use...invent something.
Old Dec 5, 2003 | 12:57 PM
whoa its len 2's Avatar
-oem style heat sheild for after market headers
-heat sheild for aftermarket intakes
-spiltters
-roll cage
-brackets/sliders
-medieval suit of armor with matching sword
Old Dec 5, 2003 | 01:22 PM
2+2=5's Avatar
Default Re: Metal Shop Project Ideas (whoaitslen2)
one piece underbody splitter
those mini-wing in the front bumper..what is it call? those little L shaped thing
one piece strut bar upper/lower
s2k style shift ****
Old Dec 5, 2003 | 01:50 PM
.bagged's Avatar
if you want to. i have a project... i just uni-body dropped my accord 2.5 inches and im all back together but strut tower bars wont line up any more. if you want to i could get you the specs i need and you could charge what you think its worth...the car is making its debut at SEMA '04 so you would have some credit too...
Old Dec 5, 2003 | 02:41 PM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoaitslen2 &raquo;</TD></TR><TR><TD CLASS="quote">
-medieval suit of armor with matching sword</TD></TR></TABLE>
yes this one is awesome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">those mini-wing in the front bumper..what is it call? those little L shaped thing </TD></TR></TABLE>
canards or spiltters. actually I think canards fit on the outside of the bumper.
you should build your own header or turbo manifold.
skunk2 style Intake manifold for the F-series.
lots of dressup items you can do...
-battery tie down
-pedal set
-dead pedal
True short shifter
Old Dec 5, 2003 | 02:45 PM
NathanMorris's Avatar
Default Re: Metal Shop Project Ideas (jweller)
a strut bar that not only ties the strut towers together, but also connects back to the firewall.
Umm, another idea would be a heatshield box for your intake filter. (if you have a short ram, and if not, you could avoid water issues by getting a short ram and going with this).....umm....maybe a sheet metal intake manifold if you don't mind doing some math and research to get it right.
- Nathan
Old Dec 5, 2003 | 03:30 PM
KTeller8's Avatar
Default Re: Metal Shop Project Ideas (92Lx)
intake manifold
do something that is new and creative but will save you money on yoru car in the future..
or build a bird feeding mail box!
Old Dec 5, 2003 | 03:34 PM
iam7head's Avatar
Default Re: Metal Shop Project Ideas (KTeller8)
exhaust gas throttle plate
Old Dec 5, 2003 | 05:15 PM
DrunkNRacer's Avatar
Default Re: Metal Shop Project Ideas (iam7head)
I would definetly hook up a heatshield for the intake.. those work great..
P.S - Metal airbags also save lives
Old Dec 6, 2003 | 09:45 AM
KGAccord's Avatar
Default Re: Metal Shop Project Ideas (DrunkNRacer)
^build a header bracket that won't crack on H22 aftermarket headers
Old Dec 6, 2003 | 09:58 AM
DIYaccord's Avatar
whoaitslen2 : splitters?
2+2=5: one piece underbody splitter?
bagged93accord : uni-body dropped? mabye i'll look into your project...just get me more info
KTeller8: got any more info on how i could do this?
iam7head: exhaust gas throttle plate...what for? what will it do?
Old Dec 6, 2003 | 10:20 AM
Nick H's Avatar
New User
Default Re: (DIYaccord)
how about this, look into making a 3 point strut bar for accords...one that goes from the strut to strut, but also goes to the firewall as well...s2k's and integra's get a lot of these, so why can't we have one?....we can if you make it...who knows, you might get rich off this ****...
Old Dec 6, 2003 | 11:00 AM
97F22B2's Avatar
how about a tubular front crossmember
Old Dec 7, 2003 | 12:02 AM
DIYaccord's Avatar
bump, read my post and answer my questions
also, any more ideas?
Old Dec 8, 2003 | 01:53 PM
.bagged's Avatar
[QUOTE=DIYaccord]whoaitslen2 : bagged93accord : uni-body dropped? mabye i'll look into your project...just get me more infoQUOTE]
i would like to have a 3 point tower bar or a neuspeed style. the only downfall is that you have to picture and take into consideration my clearance. my upper a-arms are now coming thru the hood so connections to the camber studs are tough. any ideas on your part..? hit me up with any more questions...
Old Dec 8, 2003 | 07:22 PM
DIYaccord's Avatar
Take some pics and i'll go from there
Old Dec 15, 2003 | 12:09 PM
DIYaccord's Avatar
bump
Old Dec 15, 2003 | 12:27 PM
2+2=5's Avatar
one more thing..upper radiator shield/shoud
Old Dec 16, 2003 | 12:09 PM
DIYaccord's Avatar
Default Re: (2+2=5)
probably....good idea
anyone else want me to make them anything after i make on for myself?
Old Dec 16, 2003 | 02:37 PM
carolinaACCORD's Avatar
Here is what you can build ME.
#1...Airbox intake. Just the box basically, i have the piping.
#2...Header heat sheild. Factory style.
#3...Topless battery box, with a hefty metal strap that wraps around it. For trunk mounted battery. Will be cutting a hole in the floor of the trunk and welding in requested box, so that the battery fits with the trunk floor.
^^^^^That's one's gonna be done soon no matter what.
Old Dec 16, 2003 | 07:29 PM
DIYaccord's Avatar
battery box i could do
Old Dec 16, 2003 | 10:33 PM
4bidden's Avatar
The problem with trying to make a 3pt strut bar is that our engines sit sooo far back, and even slant back. If you had a 3pt strut on there, it'd be in the way of quite a bit of stuff. It would also have to wrap around the IM, or come darn close to it.
Old Dec 16, 2003 | 11:21 PM
iam7head's Avatar
Default Re: (4bidden)
try make this for a f23, i'll give you 500dollar paypal
Old Dec 17, 2003 | 07:04 AM
DIYaccord's Avatar
um...you want me to make that WHOLE thing...or just the pipes and bracket?
eh...looks a little too hard
