determining a good compression for a built motor
i recently posted up about my brothers motor that is burning lots of oil and making funny sounds ( havent heard them myself....so i cant say what they are)
......but anyways
here is the setup:
B18B
Arias 10.5:1 CR slugs
Crane cams
etc etc...
the mechanic who built the engine told him that the compression is actually a little lower than 10.5:1 because of cam overlap....is this BS ?
so now we are going to do a compression check to see how healthy shes doin....
What compression should would be healthy for this block ?
i estimated about 210-215 psi.....
any thoughts ?
......but anywayshere is the setup:
B18B
Crane cams
etc etc...
any thoughts ?
as long as there is no 20% deviation from the average #'s then it should be fine.
edit: i meant the compression should be fine, not necessarily the engine
[Modified by In7egrity, 12:24 AM 9/18/2001]
it was just stated... as long as there is no more than 20% deviation between the #'s then the compression is fine... there is no specific # it should be at
i understand this, i was just curious as to what it should be...
ryan, no he is not running boost. I cant think of where i said that he was...
just curious.....is there ever a situation where all cylinders will have bad compression ? I know its usually just one or two, but does it ever happen to all 4 ?
efking1985
Jul 26, 2007 07:13 PM
siis2fast
Jun 16, 2003 11:09 AM
