Civic VT, b16a1 --> b18c6 (OBD Question!)
Hi!
I have a Civic VT b16a1 and a b18c6 engine, I'm going to use the Y2 gearbox with the b18c6 ECU.
The question is, were do I buy a converter for OBD1 to OBD2, because i want to use the stock cables from the car.
Regards Crazy John
Regards Crazy John
What car are you putting it inot? The B18C6 is OBD II and hte B16A1 is OBD 0. If you are putting the B18 into a OBD 0 car (sounds like it because of the tranny issue), you could just swap the complete intake manifold and distributor from the B16 onto it. For the conversion to run the ECU www. jdmhondaparts.com has them I believe.
crxhybrid1320
Jun 9, 2004 07:42 PM
The Mole
Jan 12, 2003 04:54 PM
