Custom exhaust or aftermarket exhaust and why???
Old Dec 4, 2003 | 06:43 PM
RS_H22's Avatar
Default Custom exhaust or aftermarket exhaust and why???
Just like the thread title says, all factors being considered...
Im the farthest thing from a rice boy and will almost never run any name brand over priced crap that I can outdo at half the price... I was in a debate with a few people that are new to the scene and think if its not Apex or some other name brand than its garbage and will make less power...
So everyone, please let your opinions on this matter fly...
Old Dec 4, 2003 | 07:09 PM
rodimus's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (RS_H22)
in the end....piping is piping.
IMO most aftermarket exhausts are just bling.
hell, the jdm itr exhaust is like 2.36 ID, is it not?
if you're not worried about the sound..straight pipe it.
other than that..i'm sure you've heard of kteller8 ...
maybe even smsp will chime in.
IMO custom is always best.
Old Dec 4, 2003 | 11:32 PM
96dc2's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (EVOL)
It's all in the specs/dimensions, not the brand names. All that matters is having the proper size (OD). And utilize straight-through mufflers/resonators.
All those aftermarket companies advertise "research and design". Gee, they all generally use the same tubing OD size, (usually 60-60.5mm for JDM, and 2.25" for USDM), same bends. How much different can there be between them, performance-wise?
Old Dec 5, 2003 | 04:48 AM
1 2 NV's Avatar
i say custom. most of the exhausts out there are too ****** small. 2 1/4 doesnt cut it. the 2 1/2" exhausts are usually ugly. id get the best of both worlds, 2 1/2" piping with a muffler of my choice. my exhaust is made out of 2 1/2 INNER diameter tubing we use at my job. where exhaust tubing is rated for outter diameter.
Old Dec 5, 2003 | 05:45 AM
user 996328629's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (1 2 NV)
Go custom 2.5 and buy mine
https://honda-tech.com/zerothread?id=697225
Old Dec 5, 2003 | 06:14 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Custom exhaust or aftermarket exhaust and why??? (Swags04)
just curious. what better gains is it going from a 2.25 to 2.5 custom piping anyways? should i be worried about backpressure?
Old Dec 5, 2003 | 06:38 AM
GsR HtCh's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (vtecb20coupe)
backpressure is a myth.
Old Dec 5, 2003 | 08:37 AM
BERT-O's Avatar
When the Tanabe RM first came out like 5 years ago, I was so disappointed when I recieved it. The piping diameter wasn't what I expected. The so called "bottle-neck" right after the cat was design with the ID of the stock CAT. The only fix to this was to cut off and re-do a piping the samesize of the rest.
Since then, I"ve used customs setups in the past, Kteller8 is what I've used in the past.
Another example, a customer of mine in a '95 GSR, had the same type of exhaust. His setup was just a Jackson blower with the Tanabe RM exhaust. He switch it to a Greddy SP (piping was a slight difference) and made an additional 6hp over his old Tanabe. On top, it was alot quiter.
I guess it boils down to what engine likes to breath out the most.
-Bert
Old Dec 5, 2003 | 08:39 AM
GsR HtCh's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (BERT-O)
for kteller8 great guy to deal with
Old Dec 5, 2003 | 09:20 AM
Lip's Avatar
Lip
Default Re: Custom exhaust or aftermarket exhaust and why??? (GsR HtCh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh &raquo;</TD></TR><TR><TD CLASS="quote">backpressure is a myth.</TD></TR></TABLE>
prove it
Old Dec 5, 2003 | 10:42 AM
Daemione's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (Lip)
I think the burden of proof should lie on those saying you need backpressure. It makes no sense.
Exhaust velocity, yes. Backpressure, no.
Oh yeah - put me down for custom. Mostly because you can't find a 2.5" OD straight-through system that uses more than one resonator. Personally, I'm going to be using 3 (a resonated cat, a standard resonator, and a moroso spiral flow).
Old Dec 5, 2003 | 10:44 AM
Lip's Avatar
Lip
Default Re: Custom exhaust or aftermarket exhaust and why??? (Daemione)
i never said back pressure was good. but its not a myth that it rather exists
Old Dec 5, 2003 | 12:38 PM
Daemione's Avatar
Well, of course it exists . . . . I assumed you were making some attempt to read between the lines.
The point GsR HtCh was obviously trying to make was that backpressure being good for performance was a myth, not that backpressure doesn't physically exist.
Old Dec 5, 2003 | 02:46 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lip &raquo;</TD></TR><TR><TD CLASS="quote">i never said back pressure was good. but its not a myth that it rather exists</TD></TR></TABLE>
of course it does, too much back pressure=bad, too little or no back pressure=bad too, it take little bit of back pressure to draw the rest of the gas out, smoothly.
i got 2.5pipe 22inch resonator with free flow muffler, all custom
Old Dec 5, 2003 | 03:01 PM
Lip's Avatar
Lip
Default Re: Custom exhaust or aftermarket exhaust and why??? (iam7head)
sometimes you guys are no fun.
i was just being a smart ***.
btw...i'll take a can of "zero back pressure please"
Old Dec 5, 2003 | 06:59 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
i got 2.5pipe 22inch resonator with free flow muffler, all custom</TD></TR></TABLE>
In case you missed it, for an N/A exhaust system you want ZERO backpressure, but high exhaust velocity.
Old Dec 5, 2003 | 07:57 PM
evilxkid's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (96dc2)
i'v always run custom but i'm running a thermal right now. i was going to make an exhaust with a thermal muffler and came acrros the whole cat back for the price of just the muffler shipped. and this one was stainless
i custom stuff.
Old Dec 5, 2003 | 10:54 PM
ranta18's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (evilxkid)
My thoughts:
Custom - Allows for bigger piping and getting rid of the pre-mufflers that most aftermarket systems have which will give less back pressure. Lets you choose the muffler style you want. But there is a lot more hassle with having the piping bent, welding on the hangers and muffler, etc. I've heard some "custom" exhaust and some sound really loud, raspy, and like complete crap.
Aftermarket - Great sound and all you have to do is drop you old exhaust and bolt up the new one. No hassles and some companies like Thermal offer an all stainless steel system for not a lot of money. Only drawback is the smaller size and more backpressure. Screw the bling bling brands like Mugen or Spoon unless its some show car.
Quote from Import Review "Just because its a a huge Japanese name, doesn't mean its great. Buy what performs well, not by brand name."
Old Dec 6, 2003 | 12:38 AM
gsrvx's Avatar
New User
Running a Kteller8 system here.
Old Dec 6, 2003 | 04:29 AM
GsR HtCh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lip &raquo;</TD></TR><TR><TD CLASS="quote">sometimes you guys are no fun.
btw...i'll take a can of "zero back pressure please"</TD></TR></TABLE>
when you said prove it i thought of american pie 2 where stiffler was like PROVE IT to the lesbians. back pressure sucks. NA is the only way to go
Old Jan 5, 2004 | 07:04 AM
KTeller8's Avatar
it all depends on the person, IMO
some people will sit and live by their name brand.. its xxx so its good and will preform..
while others will go and do it themself, go custom, and are extremly happy..
if you got the resources and availabilty, why not go custom.. at times it cheaper..
if your more of a bolt up , and run *lazy * kinda guy.. then go with an aftermarket system
only reason id ever suggest aftermarket, is if it was a totally different design, side exit or something that you could get done with a prefab custom kit.. well you could. but ya know what i mean
Old Jan 5, 2004 | 01:33 PM
JDM2ndGen's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (KTeller8)
me im goin with custom madrel bent 2.5" pipeing and a 3" apexi N1 muffler with no cat... i was goin to go with either tanabe or the rs*r but from what i seen with my friends cars who have these catback they were disapointed ...
Old Jan 7, 2004 | 07:53 AM
KTeller8's Avatar
Default Re: Custom exhaust or aftermarket exhaust and why??? (JDM2ndGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">me im goin with custom madrel bent 2.5" pipeing and a 3" apexi N1 muffler with no cat... i was goin to go with either tanabe or the rs*r but from what i seen with my friends cars who have these catback they were disapointed ...</TD></TR></TABLE>
might want to pick up a 2.5" Muffler to fit that piping
efn91
Welding / Fabrication
Feb 17, 2009 10:53 AM
JasonST
Dec 2, 2006 03:42 PM
dawrenn
Mar 15, 2005 04:36 AM
Hairy Gorilla
Sep 19, 2002 03:45 PM
