Nitrous on my r
Old Sep 17, 2001 | 07:28 PM
Pinhead's Avatar
New User
Default Nitrous on my r
I'm about to go from 85 shot wet single fogger to 100 shot direct port on my type R and I was wondering what upgrades I would need(i.e. fuel upgrades, ignition) right now I just have my timing retarted 2 degrees and I use regular 93 octane fuel and no problems with anything...I also have basic I/H/E cam gears, vafc, accel wires
Old Sep 17, 2001 | 07:43 PM
jimbob's Avatar
New User
Default Re: Nitrous on my r (typerman1358)
Just asking, but why? NOS? On an R?
Old Sep 17, 2001 | 07:49 PM
Dan's Avatar
Dan
Default Re: Nitrous on my r (jimbob)
100 shot!! going ***** out huh.
Old Sep 17, 2001 | 08:04 PM
EVOCELICA's Avatar
New User
Default Re: Nitrous on my r (ITR 1413)
100 shot direct port you might want to upgrade your pump or put an inline pump you should be ok just keep checking your plugs. I have seen GSR's run 100 direct port before so your R should be ok
Old Sep 18, 2001 | 04:59 PM
TurboR1391's Avatar
I would definitely get an external ignition and a coil to keep the spark burning strong. Also you are going to need a fuel pressure regulator and another fuel pump(larger intank or either inline) to compensate for the fuel. These are the things I used to run my old hatch with an ITR motor. The setup was a 80 shot direct port nitrous kit. The hatch actually ran a best time of 12.3@110mph at the NOPI Dragwars in Houston, TX in February of this year.
Old Sep 18, 2001 | 05:03 PM
FAST94GSR's Avatar
New User
Default Re: Nitrous on my r (Vonte')
Direct port is the way to go however running a 100 shot is on the edge. You better make sure you have enough fuel. If I were you I'd use 80 max. too many stories I know personally didn't work out with 100 shot.
724chris
Jul 21, 2010 09:35 AM
TeamDOHCside
Jan 7, 2004 06:27 PM
CM-R
May 7, 2002 01:43 PM
xxplosif1
Apr 21, 2002 07:06 AM
KevronsEG
Jan 10, 2002 02:21 PM
