Uprading fuel system for turbo?
Old Dec 4, 2003 | 03:31 PM
Pete_SI's Avatar
Default Uprading fuel system for turbo?
Hi,
I look a lot of turbo kits (or even custom kits) and they do not come with an upgraded fuel system or a tuned ECU. I justs want to know if you run around 7 PSI of boost would a upgraded fuel system or even a tuned ECU be necessary.
Old Dec 4, 2003 | 03:36 PM
boostsohfast's Avatar
Default Re: Uprading fuel system for turbo? (Pete_SI)
I don't know what turbo kits you are looking at but there must be something to keep the map sensor from seeing boost and whatever device people choose to do this usually manages fuel also with the exception of check valves. Even with them you need at least a fmu to give more fuel. For 7 psi I would upgrade the fuel pump just to be safe.
Old Dec 4, 2003 | 04:12 PM
Pete_SI's Avatar
Default Re: Uprading fuel system for turbo? (boostsohfast)
Does this usualy comme with the kit?
Old Dec 4, 2003 | 04:19 PM
igotyofire's Avatar
let us know what kit, better yet look at the kit and see what it comes with..should either come with a FMU and a inline fuel pump, bigger injectors....
Old Dec 4, 2003 | 04:22 PM
Pete_SI's Avatar
Default Re: Uprading fuel system for turbo? (igotyofire)
Alright....the only reason I ask this is I want to know if I can install a turbo kit myself
Old Dec 4, 2003 | 05:23 PM
Johnyquest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI &raquo;</TD></TR><TR><TD CLASS="quote">Alright....the only reason I ask this is I want to know if I can install a turbo kit myself</TD></TR></TABLE>
easily, as long as you can tie your shoes and change your oil-- okay, it's not that easy... but hell, i went from being 16 and having no car, just basicalyl knowing how to do oil changes, to getting my honda, to doing the timing belt / brakes / clutch / then finally making my own custom / junkyard turbo kit and installing it!!! (i pretend like the N/A years didn't happen, and kick the header every time i see it sitting in the garage)
Old Dec 5, 2003 | 02:05 AM
Pete_SI's Avatar
Default Re: Uprading fuel system for turbo? (Johnyquest)
LOL...thats pretty good....I guess then I'm not going to waste my money on DC sports header then.
Old Dec 5, 2003 | 12:12 PM
Johnyquest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI &raquo;</TD></TR><TR><TD CLASS="quote">LOL...thats pretty good....I guess then I'm not going to waste my money on DC sports header then.</TD></TR></TABLE>
You want a header? I have an OBX header in real nice condition, stainless steel, I'll do it for $100 shipped if you choose not to turbo. It'll probably only make like 5-6hp, but It does make the exhaust note cleaner and more uniform; anyways, it's just incase.
Old Dec 5, 2003 | 01:24 PM
Pete_SI's Avatar
I think I'm going to save the money and wait next summer for the turbo.
I BOOST
OptPrime
Jul 17, 2005 09:40 AM
Tad
Oct 3, 2004 02:02 PM
92civiclsb18a
Jun 30, 2004 08:41 PM
LudeSi-93
Jun 15, 2001 10:01 AM
