Lighter Power Fuse
mine went out too. i know its not under the dash, i checked that yesterday. haven't had time to check under the hood in those fuses. gonna do that today. the light in my ash tray is out too, pretty sure they run off the same fuse.
I looked under the hood.. couldn't find it.
Inside the car it might be the accesory one but its not blown.
Is it the accessory one... I dunno???
Ok I did some research:
There are two fuses to check and one relay:
1)Fuse under the hood, top row second from left (fuse 46)
2)Fuse under the dash, top row at left end (fuse 18)
3)Cig lighter relay under the dash, top row center
all from the helms... wow i didn't know a cig lighter circuit can be so complex. It is due to the fact that it only gets power when the igntion switch is on which powers the coil to the relay.. gonna tackel this on the weekend.
Hey check this out broe. Something like that happened to me and I checked all fuses and they were fine. If you did that already then it must not be that right. So then I thought it was my lighter and I needed to buy a new one... Well I took out the little box where you can put your coin chance or whatever and the lighter was just unhooked....
I don't know how it happened....but you should check it out just in case and if it's that it might save you time thinking is something alse.
Let me know what happend with this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECRaZeR »</TD></TR><TR><TD CLASS="quote">Hey check this out broe. Something like that happened to me and I checked all fuses and they were fine. If you did that already then it must not be that right. So then I thought it was my lighter and I needed to buy a new one... Well I took out the little box where you can put your coin chance or whatever and the lighter was just unhooked....
Let me know what happend with this.</TD></TR></TABLE>
me too dogg
me too dogg
eqrunner
Honda Civic (2016 - Current)
Aug 7, 2017 06:18 AM
