Disc to Drum Conversion Problems
Old Dec 4, 2003 | 06:56 AM
JDMpress's Avatar
Default Disc to Drum Conversion Problems
I'm considering buying a friend's 94 Accord as a beater car. It originally had rear disc brakes with ABS, but he took swapped it with drums from a 93 Accord. Anyway, the brakes were bleeded, but they still feel pretty mushy. Is this normal, and if not, what are possible causes/fixes? I don't care if the ABS doesn't work, but is that a possible reason that it doesn't feel right?
I just don't wanna buy a car and have it screw me over when winter and the snow comes...
Jean
Old Dec 4, 2003 | 07:21 AM
Jim Truett's Avatar
Default Re: Disc to Drum Conversion Problems (JDMpress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMpress &raquo;</TD></TR><TR><TD CLASS="quote">I'm considering buying a friend's 94 Accord as a beater car. It originally had rear disc brakes with ABS, but he took swapped it with drums from a 93 Accord. Anyway, the brakes were bleeded, but they still feel pretty mushy. Is this normal, and if not, what are possible causes/fixes? I don't care if the ABS doesn't work, but is that a possible reason that it doesn't feel right?
Jean</TD></TR></TABLE>
The brakes are still mushy because it now needs the proportioning valve for an Accord with rear drums. The disc brake proportioning valve does not leave residual pressure on the drum brakes, which they need to work properly.
Old Dec 4, 2003 | 07:29 AM
JDMpress's Avatar
Default Re: Disc to Drum Conversion Problems (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
The brakes are still mushy because it now needs the proportioning valve for an Accord with rear drums. The disc brake proportioning valve does not leave residual pressure on the drum brakes, which they need to work properly.</TD></TR></TABLE>
Do you know what this looks like? We still have the 93 Accord. I assume we could just swap that in...
Jean
Old Dec 4, 2003 | 11:33 AM
JDMpress's Avatar
I also forgot to ask...
Will it matter that there's no more ABS?
Jean
ColeCooper90
Nov 28, 2018 07:40 AM
Irishweird00
Jul 14, 2009 02:30 PM
toda_eg6
10
Dec 27, 2005 10:23 AM
civic_tuned
19
Jun 4, 2004 10:22 PM
Dveloped
10
Nov 12, 2003 02:13 PM
