whats the c/r on h22a1? help
what is the compression ratio on a h22a1 ,cause my h22a pistons siezed .
and will it lower my hp ,and can i get a gasket to raise the compression
to make back to my old h22a setup ,im a 3rd gen so i know not as much
about this engine as i know the b20a . thanks
the bearings spun and i heard a rod knock and
bam the motor died right before my eyes, so
i dident have money for a new motor so i bought a block from a hondatech member for 500.00 im just concerned that my hp wont be as much so im wondering if i can increase it by
head gasket or milling the head?????
*IF* you have a JDM engine swapped in your car that you spun a bearring the compression is 10.6:1 or 11:1 ...
USDM is 10:1
so yes, you will loose a bit of power if you goto a USDM block with stock USDM internals.
if you want to raise compression you can mill the head and/or get a higher compression gasket. Both are options that have been used on many H22's.
USDM is 10:1
coomplife05
Mar 15, 2012 06:00 PM
CRXNuts
Apr 17, 2004 05:56 AM
