painting valve cover
hey guys. i took off my valve cover tonight and tomorrow i'm bringing it to my friends shop to paint it. but my question is for those of you who already done this before which is the best way to cover up the DOHC VTEC and HONDA MOTOR CO. words so they don't get sprayed?
TIA
TIA
Heres mine that I did for fun. (It was a spare valve cover)
I just painted the whole thing, then when it was dry I went over the letters with a sanding bit on an air gun.
i used vaseline on the letters of my valve cover........the paint peels off like butter over the areas you apply it to.....
I sanded the the tops of the letters down perfectly flat with 200 grit on a sanding block before i painted it. painted the whole thing, taped around the letters and block sanded the paint off of them. washed it and clear coated it. the definition is very sharp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- »</TD></TR><TR><TD CLASS="quote">DAMN! Sukebei Oni that valve cover looks fresh..where did you get that color?</TD></TR></TABLE>
more info here.
https://honda-tech.com/zerothread?id=580655
more info here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC_VTEC »</TD></TR><TR><TD CLASS="quote">which is the best way to cover up the DOHC VTEC and HONDA MOTOR CO. words so they don't get sprayed?
chapstick.
chapstick.
Heres what you do, clean that piece with some hot water and just a little bit of soap. The less fufu soap the better. Then take a Wax and grease remover and scrub it with that. Then sand with a red scotch brite (easier to get in all the curves and stuff. Then Hit it with etch primer in a aerosol. Then what ever you want after that for color. If it gets over 250 degrees farenhiet then boom you dont have a valve cover no more. Just messing around, Most paints can only take about that hot before they chalk yellow or burn off. I personally like Dupli-Colors Metal Cast Line for small easy projects like that. Good Luck.
AlphaQup
184
May 29, 2014 09:06 PM
pjr710
Paint and Body
17
Aug 15, 2008 05:43 AM
turbotime
Nov 7, 2005 07:31 PM
