Signs you need a valve adjustment?
Old Sep 17, 2001 | 03:27 PM
ken's Avatar
ken
Default Signs you need a valve adjustment?
What are some of the signs that you need a valve adjustment?
The other night, I noticed a slight ticking noise when I'd let my foot off the throttle at higher rpms. First thing that came to mind was a valve adjustment, since I have 79k and haven't done one at all (atleast since I bought the car at 60k, and I doubt the dealership did it).
Thanks.
Old Sep 17, 2001 | 03:38 PM
dustin's Avatar
Default Re: Signs you need a valve adjustment? (SeaDawg)
You can typically only tell that a valve adjustment is necessary because of ticking at idle. If it is ticking a lot, then adjust the valves. It takes like 30 mins. I think valves are supposed to be adjusted every 15k miles or so.
Dustin
Old Sep 17, 2001 | 03:53 PM
ctiburcio's Avatar
New User
Do your engine make this noise after it's hot? There's another phenomenon called piston slap. It happens when the car is cold and the pistons haven't expanded to their full size due to the heat created in an internal combustion engine. This should only happen when your car is cold.
The best way to determine if you need a valve adjustment is to just go ahead a do one, and 48000 km latter do it again. This is the recommend maintenance interval from the factory.
Old Sep 17, 2001 | 05:36 PM
fixhondas's Avatar
Valves can be loose and make noise but just because they may not be noisy does not mean they are correctly adjusted. Valves that are too tight will cause a rough idle but you won't hear it. Also- when a timing belt on a dohc honda is stretched and/or loose it will sound like loose valves. Adjust your valves and check your tbelt- make sure when adjusting the valves that the engine is 100 degrees or cooler or the adjustment will be a waste of time.
Old Sep 24, 2001 | 08:18 AM
jebarco1's Avatar
New User
Default Re: Signs you need a valve adjustment? (fixhondas)
Hey, it wouldnt hurt to get some prolong, and a new valve cover gasket , and adjust them joints. Never know when i might roll up on you, im eg6 or mr2 turbo..later
Old Sep 25, 2001 | 02:47 AM
Mr. Choi's Avatar
New User
Default Re: Signs you need a valve adjustment? (jebarco1)
prolong? hahaha that thing is bull$hit. my friend and i put some prolong in a 89 legend, drove it around for two days, drained oil on the 3rd day and started the engine and held it att 5k rpm. lets say that buick v8 in the commercial is BS. our engine lasted about 2 mins before it siezed up. why did we do this? we did the "prolong challenge" because the engine had many miles and the owner wanted a new engine, so we got a used engine from artico or something to swap it. prolong is a fake.
Old Sep 25, 2001 | 04:06 AM
jebarco1's Avatar
New User
Default Re: Signs you need a valve adjustment? (Chois i-VTEC)
Maybe the prolong challenge is something that we would do with our expensive vtec motor (and you dumm *** if you did) But the quality of the additive is good for you engine, coat the engine parts, less friction. Anyway,, whatever to what ya boy said, get some and add, it works. But dont do the extreme and drain your oil,, lol
jond
Acura NSX
Jan 4, 2008 08:21 AM
redpeppers
Jul 26, 2005 02:33 PM
Luserkid
Jul 19, 2003 08:12 AM
XenonDepot
Apr 18, 2003 12:44 AM
GreenMachine
Jan 14, 2002 04:01 PM
