How do I find a crack in my manifold?
I recently hit a dip that did in my downpipe. I had a new downpipe made that was about 3.5" higher, so I don't have any clearance issues, but now I still get a whiff of exhaust from time to time, and especially when the car is still cold and I jump on it. I have a cast mani, and I figure it must be a crack, although none are visible. Is there any way to try and locate the crack so I can fix it until I can get another mani?
start your car & let it Idle.
get a piece of hose or something and use it as a stethascope.
If exhaust gases are coming out you will be able to pinpoint the crack by listening to it.
Get one of those drug sniffing dogs, like they have at customs.
Or, light up your crack pipe and blow the smoke in the general area of the suspected leak (making sure other sources of air have been isolated) Watch the smoke, it will be blown away from the area of the leak.
BTW, stop smoking crack and dealing it to our kids
NDT
non-destructive test spray.
pick it up at your local welding supply store. 3 spray cans: cleaner, fixative, and developer. if there is a hairline crack, it will dye it red.
although... i would think that if the crack were large enough to start leaking exhaust, you'd be able to see it, and you would see carbon trails.
also, since the damage to your downpipe was so severe, as to make you worry about the manifold, i would be worried about the exhaust housing, as well.
and:
if you only get the whiff of exhaust smell when your car is still cold, then maybe your cat just hasn't had time to pre-heat.
and:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee »</TD></TR><TR><TD CLASS="quote">You can usually find soot trails when you have a crack.</TD></TR></TABLE>
attica
13
Dec 2, 2009 09:18 PM
fipracing_com
Aug 15, 2004 08:12 PM
91DA9
Apr 22, 2002 09:34 AM
