is a distributor rotor suppose to be tight or have a little play in it?
my distributor rotor is loose you can shake back and forth and just has a lot of play in it is it supppose to be like this or is it suppose to be tight. still trying to fix my missing problem someone please help me.
Are u talking about the rotor with the two notches that go into the intake cam?? That rotor should move side to side a little, if you look at the intake cam where the dizzy goes the slot is offset to one side and so is the rotor. There shouldn't be any other play anywere in the distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx000 »</TD></TR><TR><TD CLASS="quote">im talking about the rotor when u take the distributor cap off the rotor that u see under the cap hooked on to the rest of the ditributor</TD></TR></TABLE>
it should be held on by a screw. if its loose,, then you got problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx000 »</TD></TR><TR><TD CLASS="quote">i think this may be my problem why my car is missing a t 6,000 rpms and above what do u think?</TD></TR></TABLE>
It just might be the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx000 »</TD></TR><TR><TD CLASS="quote">one more ? can u tell me where the screw that goes into the rotor is
Its on the shaft portion of the rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx000 »</TD></TR><TR><TD CLASS="quote">thanks man you've been a big help i appreciate it</TD></TR></TABLE>
Not a problem.. hope it solves your problem
yangkm
Feb 26, 2011 04:20 PM
civicproblems
Jan 6, 2005 04:05 PM
