driving car cold
Old Dec 3, 2003 | 01:44 PM
machine4321's Avatar
Default driving car cold
ive got *** loads of snow where i am now and its been very cold....my car is a little to loud to be warming up for to long in the morning..people bitch and complain ..
basilcly i always give it a couple minutes to get going...
i wont take it over 2500 rpm when its cold it sounds kinda constrricted over 3000rpm....
is this really bad for the motor ..opinions please
Old Dec 3, 2003 | 02:06 PM
rapid_roy's Avatar
Default Re: driving car cold (machine4321)
Nope.
You don't need to let it idle for more than 30 seconds when you start it up though. No real point in it, as long as you are keeping the RPM's low until it warms up you should be fine.
Cheers,
Roy
Old Dec 3, 2003 | 02:55 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
driving a car cold is not good in a whole...when your motor isnt up to temp the pistons havent expanded completly causing premature ware from a slightly rocked piston...BUT..on a stock motor with cast pistons with factory(tight)P-W clearences this wouldnt harm the motor until thousands of miles down the line of doing this everyday.....if u have a motor with forged internals with looser tolerences this will cause premature ware A LOT sooner and should not be done!......but like i said if your motor is considerably stock (internally)the way u are handling it should be sufficiant.
Old Dec 3, 2003 | 05:49 PM
91tegrals's Avatar
yeah i dont se a prob with the way youre handling it..
Old Dec 3, 2003 | 06:25 PM
cool thanls guys
Old Dec 4, 2003 | 06:34 PM
doublejz's Avatar
Default Re: (machine4321)
you will be ok, as long as your not beating the **** outta it while its cold
umair
Feb 22, 2009 12:29 AM
red91sit
Jan 10, 2005 06:48 PM
Seedc2
Aug 14, 2004 04:35 PM
Boostless97Lude
Jan 11, 2003 09:53 PM
simple4012
Jan 3, 2003 05:11 AM
