I need the exact spec of the SKUNK2 stage II cams , please
Old Dec 3, 2003 | 12:14 PM
douglas_be's Avatar
Default I need the exact spec of the SKUNK2 stage II cams , please
Not the valve lift and duration , but who can tell me at what point the lift starts and ends , and how much lift at what timing , maybee a diagram ?
Thanks
DOUGLAS
Old Dec 3, 2003 | 12:38 PM
deepgreengsr's Avatar
Default Re: I need the exact spec of the SKUNK2 stage II cams , please (douglas_be)
are you trying to have copies made? This is kinda hard without the actual cam in your hand. your nest bet would e to buy the cam and copy it. then return it or sell it on ebay.
Old Dec 3, 2003 | 12:46 PM
douglas_be's Avatar
Default Re: I need the exact spec of the SKUNK2 stage II cams , please (deepgreengsr)
I have the cams , but now I am building a new engine , and my tuner needs it ti work on the engine!
Old Dec 3, 2003 | 01:53 PM
99blackcivicSi's Avatar
well if he is ur tuner and is building the motor he should have access to these things.
Did your cams come with a cam card?
Old Dec 4, 2003 | 12:42 PM
douglas_be's Avatar
Default Re: I need the exact spec of the SKUNK2 stage II cams , please (99blackcivicSi)
Here in Europe we don't have all this information available , the cams didn't come with the card ?
Old Dec 6, 2003 | 08:09 AM
meanEG's Avatar
if your tuner is building the engine, he should be able to measure it with a dial indicator, and degree the cams in.
Old Dec 18, 2003 | 05:10 PM
TyPe_R_GuY's Avatar
Well I have Skunk2 Stage 2 Cams and I have the paper that cam with them, it reads.....
Intake: LIFT@0" lash: 0.485" (12.3mm)
Opening@1mm: 37 degress BTDC
Closing@1mm: 49 degress ABDC
VALVE LASH: 0.007" (cold)
Exhuast: Lift@0" lash:0.466" (11.8mm)
Opening@1mm: 61 degress BBDC
Closing@1mm: 21 degrees ATDC
Valve Lash: 0.008" (cold)
hope this helps on what you needed
Old Dec 18, 2003 | 09:06 PM
douglas_be's Avatar
Default Re: I need the exact spec of the SKUNK2 stage II cams , please (TyPe_R_GuY)
Thank you , TyPe_R_GuY
Douglas
dommyy13
Oct 26, 2012 11:05 AM
HyperFlow
Jun 6, 2010 11:55 AM
VTIargentina
May 29, 2010 07:54 PM
crxb16a90
Feb 15, 2010 07:03 PM
acura_b18c1
Jan 8, 2006 06:58 PM
