Any things I should replace before I put in a new motor?
Old Sep 17, 2001 | 12:32 PM
Night Kid's Avatar
New User
Default Any things I should replace before I put in a new motor?
belts? spark plugs? ignition wire?
Old Sep 17, 2001 | 02:59 PM
HXMan's Avatar
Default Re: Any things I should replace before I put in a new motor? (civicnightracer)
Timing belt, water pump...maybe oil pump, spark plugs, PCV valve, whatever is easy when the engine is out, but hard once put in....maybe a new clutch too.
Old Sep 18, 2001 | 02:53 AM
FaTBastarDinaCiviC's Avatar
New User
BRAKES are a must if your puttin a B18 in there, exhaust mani-gasket. Check out all your belts and pulleys, axles, exhaust, fuel pump (optional). Also make sure you got the right mounts and brackets (rear tran. bracket).
Old Sep 18, 2001 | 04:39 PM
court's Avatar
25 Year Member
Default Re: Any things I should replace before I put in a new motor? (FaTBastarDinaCiviC)
i wouldnt go as far as saying replacing the brakes for a "B18" is needed
maybe when you are hitting low 13;s it would be a good idea
your budget should dictate what you should replace
Old Sep 18, 2001 | 08:16 PM
Night Kid's Avatar
New User
Default Re: Any things I should replace before I put in a new motor? (court)
well, i have around 200 left
Old Sep 18, 2001 | 09:32 PM
New User
True, he didn't say if it was an Si or not, if your working with stock dx its a must. Don't forget to replace the throttle cable.
Old Sep 20, 2001 | 08:49 PM
Night Kid's Avatar
New User
is a brake that NEEDED?? mines a DX by the way
Old Sep 20, 2001 | 10:35 PM
Blue-Civic-Hybrid's Avatar
Loved
This is what i replaced when I did my swap..
1) timing belt
2) water pump
3) ACT clutch and checked my flywheel
These are probably the hardest things to change with the motor in your car, it is work the time and money when the motor is out and the piece of mind.
Old Sep 21, 2001 | 03:21 AM
New User
Look man i'm just tryin ta keep ya safe. Think about it more weight + extra H.P. = less stopping power, especially on the street or in traffic. Now i'm not sayin go out and spent $3-400 on a big brake conversion but at least upgrade your rotors. http://WWW.OPTAUTO.COM sells slotted rotors for a dx for about $60 each. Your stock rotors are fine they'll just wear a little quicker.
Old Sep 21, 2001 | 09:07 AM
Night Kid's Avatar
New User
thanks for the info...
viccard
Honda Civic (2006 - 2015)
Jun 21, 2008 12:35 PM
saikou
Aug 5, 2007 10:47 AM
aandrewcc
Mar 26, 2006 08:30 AM
Bigjon
32
Jul 19, 2003 07:36 AM
imported204
Apr 27, 2002 11:23 AM
