clicking noise when trying to start up car?
so i went to start my car this morning and it won't start. instead it makes this rapid clicking noise (i htink it may be the distributor) and sometimes the speedo needle will jump. i have no idea what's going on. andyone else have this problem? thanks in advance
-marc
-marc
the thing is though that everything else works in accessory position. my interior and instrument lights are all lit. i can hear my cd changer working and i'm able to flip up and down my monitor. i highly doubt that it's the batter cuz i can hear the clicking noise coming from under the hood. it's pretty loud. anybody have any ideas? thanks
also, anyone know why the speedo needle is jumping?
-marc
-marc
Bump because I have the same problem. Clicking and speedo jumping sometimes. It did this, it finally started once, now I can't get it to start again.
turns out my battery was bad cuz it had beed drained and recharged so many times. i guess eventually it stops putting out enough voltage to turn the starter. try jumping the batter, and if that works then your battery is bad so get a new battery. if that doesn't work, you may have a bad starter. good luck
My battery is new and is fully charged. I'm going to change the starter tomorrow with an extra I have...thank god for spare swap parts sitting around in boxes.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcdogg816 »</TD></TR><TR><TD CLASS="quote">turns out my battery was bad cuz it had beed drained and recharged so many times. i guess eventually it stops putting out enough voltage to turn the starter. try jumping the batter, and if that works then your battery is bad so get a new battery. if that doesn't work, you may have a bad starter. good luck</TD></TR></TABLE>
yea usually when the needle jumps like that i guess it means yer battery's dead...haha had to find that out the hard way when i tried to push my **** to work.
i tohught it would go, but my battery died like 2 mins after i left.
-marc
-marc
My 2001 Civic lx is having the same issue but when I try to start it acc everything shuts down had the OBD2 scan tool plug in and it did the same thing as everything else I took out fuse #17 and everything went normal except for the aftermarket stereo it just blinks on and off all ground have been sanded and clean why☹️ I don't have any money so I'm doing everything myself
gosaha95
Honda Civic (2001 - 2005)
Jul 20, 2015 08:40 PM
RTW DC2R
Apr 28, 2006 12:44 PM
letmeseeyouskip
Mar 10, 2005 07:49 PM
