B18A1 ?'s
Old Dec 3, 2003 | 10:48 AM
LegoZ81's Avatar
Default B18A1 ?'s
I was thinking about rebuilding my teg engine, what all would I need to replace?
I have a head from a 99 CRV (B20) so I do not need to know the top end stuff.
I know I will need to replace:
Main Bearings
Rod Bearings
possibly bore .25 over IF I do the below P30 Pistons and rehone
If no bore/P30 then hone only.
Rings
Replace head gasket & head bolts "studs"
Oil Pan gasket
I am also thinking about using USDM B16A (P30) Pistons in it to yield higher compression, has anyone done this and is it just drop-in?
I would leave stock Revlimiter in effect.
-omg- I did not ask this! lol
basically should I fix this one or try to find a used LS short/longblock?
Modified by LegoZ81 at 10:24 AM 2/17/2005
Old Dec 3, 2003 | 11:03 AM
hotintegranights's Avatar
Default Re: B18A1 ?'s (LegoZ81)
y not just get a b20b block probably end up cheaper than the rebuild and def feel alot more torque for your DD.
Old Dec 3, 2003 | 05:11 PM
LegoZ81's Avatar
Default Re: B18A1 ?'s (hotintegranights)
that was what I was thinking, haven't looked TO much but I am wanting a stock bottom end as I already have a head and I would like lower milage also if I go that route, and anyone know what needs to be done to be a b20 into a DA? just drop in and swap sensors?
Old Dec 3, 2003 | 05:50 PM
yep just drop in same block casing as your stock b18a block
Old Dec 3, 2003 | 07:43 PM
PearlCrx's Avatar
hmmmm I would go CTR piston .25 to freshen things up, you are automatic hey.........get a torque converter first thing
Skunk2 manifold and crower 403's
good luck
MEn'MYEK
Mar 11, 2012 08:49 PM
vtechjunkie
Dec 1, 2008 07:34 AM
crxstylin
May 20, 2008 07:40 AM
ludelvr
Apr 6, 2004 04:41 PM
LegoZ81
Sep 2, 2003 07:51 PM
