will 15 inch kosei k1 with 38 offset fit a 2001 prelude?
Old Dec 3, 2003 | 10:31 AM
racekar's Avatar
Default will 15 inch kosei k1 with 38 offset fit a 2001 prelude?
will there be any fitment issues? i know the old kosei used to be 42 offset thanks
Old Dec 3, 2003 | 10:34 AM
577HondaPrelude's Avatar
Default Re: will 15 inch kosei k1 with 38 offset fit a 2001 prelude? (dchung1)
They don't make the 42 offset anymore? Darnit! I was going to get a 2nd set of kosi rims. If that is the case then I would also like to know if they fit.
Old Dec 3, 2003 | 10:56 AM
bad-monkey's Avatar
depending on what tire you run and what your ride ht is, i think they CAN fit...
the PO.com database says "gray area, risk rubbing outside of wheel wells"
Old Dec 3, 2003 | 11:51 AM
aklucsarits's Avatar
New User
You need to tell us how wide the wheels are.
I have 16x7.5" K-1s with the +42mm offset. And they rubbed like a **** on the front fenders until I put much stiffer Springs up front. (They never rubbed on the street, just at autoX). So I would say that +38mm is probably a no-go regardless of width.
Andrew
Old Dec 3, 2003 | 03:46 PM
racekar's Avatar
i believe it is 15 x 7 inches
Old Dec 3, 2003 | 03:52 PM
racekar's Avatar
i also checked the tire calculator and stock is 205/50 and if i put the 205/50 on 15's its an overall smaller diameter which might help the rubbing issue but not sure.
Old Dec 3, 2003 | 06:23 PM
del_parker's Avatar
Default Re: (dchung1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchung1 &raquo;</TD></TR><TR><TD CLASS="quote">i also checked the tire calculator and stock is 205/50 and if i put the 205/50 on 15's its an overall smaller diameter which might help the rubbing issue but not sure.</TD></TR></TABLE>
mine still rubs up front with 205/50/15s.
+42 offset
hondapeeler
Dec 2, 2010 08:59 AM
deck1
Feb 5, 2008 09:13 PM
onlyneed4
Jul 27, 2005 04:56 PM
SantaCruz92Si
Jul 22, 2003 01:36 PM
Ross
17
Jan 29, 2002 06:08 PM
