loss of clutch fluid?
Old Dec 3, 2003 | 10:20 AM
myhatchrips's Avatar
Default loss of clutch fluid?
for some reason ive noticed that my clutch fluid is ending up all over the floor board. i have to top off my clutch reservoir every 3 days . any of you guys have similiar experiences? thanks for any input. btw i already did the bleeding procedure to remove air from the system.
Old Dec 3, 2003 | 11:33 AM
HAccord96's Avatar
Default Re: loss of clutch fluid? (myhatchrips)
I had a similar experience whenever my clutch master cylinder was leaking. After I replaced it, the clutch pressure was back to being stiff, and the clutch didn't slip anymore. Check to see if you have any loose connections inbetween your clutch master, hard clutch line, and slave cylinder.
Old Dec 3, 2003 | 10:56 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
you need a new master cylinder.
Old Dec 4, 2003 | 06:26 PM
doublejz's Avatar
Default Re: loss of clutch fluid? (not so civic)
check all the fittings to make sure they aren't leaking if everything looks good, probably your master cylinder
Old Dec 5, 2003 | 07:21 AM
MUGEN_B16CIVIC's Avatar
Default Re: loss of clutch fluid? (doublejz)
Mine is doing the same ****...It sucks...But yeah its the master cylinder..there more than i want to pay but its better than having clutch fulid all over your fool board...its a pain in the *** to get out to...but oh well "**** IT"
PaulMc
May 18, 2014 05:04 PM
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
OMGWTFBBQ!
May 27, 2008 11:13 AM
g00se
Mar 8, 2004 06:11 PM
SlowPoke
Nov 25, 2002 09:36 AM
