Best Vtec CAM ?
Old Dec 3, 2003 | 09:20 AM
LODOSS's Avatar
Default Best Vtec CAM ?
which vtec cam produce the most low end and mid range power?
Old Dec 3, 2003 | 11:28 AM
patdemps's Avatar
Default Re: Best Vtec CAM ? (LODOSS)
search.....
depends what kind of power your looking for, what kind of motor your running it on, etc. a bit more information would help. there is a ton of cams out there.....
Old Dec 3, 2003 | 11:33 AM
eyeamvic's Avatar
Check out this dyno. Look at those Type R cams pull up until 7k. Not bad for cams that came stock on a car.
Type-R in red
Jun 3 in blue
Toda C in Green
Old Dec 3, 2003 | 11:36 AM
Ryan C's Avatar
Default Re: Best Vtec CAM ? (eyeamvic)
I just picked up some CTR's from what i've heard you cant go wrong.
Old Dec 3, 2003 | 11:52 AM
ITRswapandslow's Avatar
RLZ stage 1's
Old Dec 3, 2003 | 11:59 AM
Ryan C's Avatar
Default Re: (RLZengineEJ6)
how much do they run? and how do they compare to CTR's?
Old Dec 3, 2003 | 12:58 PM
PM MAX_CFM for more info
Old Dec 3, 2003 | 01:01 PM
LODOSS's Avatar
like is said. low to mid range power.. so i am more curious on which cams got the best profile on its LOW lobe. I know CTR AND ITR are good but i've seen a lot of people and dyno showing the skunk 1's tearing them apart in the mid range while still giving it a lil more power up top too.
carthik
Jan 13, 2015 03:29 PM
smithb299
Dec 2, 2008 07:52 AM
B18C_DD
25
Jun 21, 2006 10:08 AM
PearlCrx
Mar 5, 2004 12:51 PM
mj_speed
Dec 17, 2003 12:11 PM
