Spoon High Tension Plug Wires
Old Dec 3, 2003 | 08:20 AM
bcrl's Avatar
Default SPOON HIGH TENSION PLUG WIRES
SPOON HIGH TENSION PLUG WIRES has any major differences compare to other brand likes NGK, etc?
Anyone has SPOON HIGH TENSION PLUG WIRES ? comments plz!
Old Dec 3, 2003 | 08:21 AM
.RJ's Avatar
.RJ
Default Re: SPOON HIGH TENSION PLUG WIRES (bcrl)
Your shift key is broken.
OE plug wires are just as good.
Old Dec 3, 2003 | 08:48 AM
B2FiNiTY's Avatar
I used to have them. Didn't notice a difference except they looked very good.
Old Dec 3, 2003 | 10:34 AM
nEoMuGen's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (B2FiNiTY)
Same here, I'm after the bragging rights when I pop the hood
Old Dec 3, 2003 | 03:59 PM
bcrl's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (.RJ)
No differences compare to stock OEM plug wires?
Except looking good when you pop the hood?
Old Dec 3, 2003 | 04:16 PM
machgo5go's Avatar
.000001 hp gain!
I tried Magnecor back in my 97R and never put them back to current 00R since it does
nothing and too big for the wire looms. Its all looks.
Old Dec 3, 2003 | 05:30 PM
B2FiNiTY's Avatar
I've done, OEM, Spoon wires, and NGK Blues (usdm version, not the expensive one) and they are all the same. Fact is, you don't really need to upgrade anything other than stock until way later on.
Old Dec 3, 2003 | 06:00 PM
MEANB18's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (nEoMuGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">Same here, I'm after the bragging rights when I pop the hood </TD></TR></TABLE>
I'm after the respect... to some that's more important.
Old Dec 4, 2003 | 02:32 PM
bcrl's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (MEANB18)
Old Dec 4, 2003 | 09:17 PM
ek4ek9's Avatar
check this out
http://www.vtec.net/articles/v...=8680
Old Dec 4, 2003 | 09:51 PM
esponet's Avatar
it really works, it help make spoon rich. so buy plenty of em.
Old Dec 4, 2003 | 09:53 PM
mr poo's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">it really works, it help make spoon rich. so buy plenty of em.</TD></TR></TABLE>
Old Dec 4, 2003 | 11:00 PM
Gerhard_001's Avatar
Spoon plug wires are nothing more then NGK blues with a grounding jacket and grounds over them. Spend over 300 for spoon or 40-50 for the NGK blues your call.
Old Dec 5, 2003 | 04:31 PM
AJ PwR's Avatar
Spoon wires sure does make a difference not just the looks. I lost 3whp across the power band when I switch the Spoons to NGK Power cable.
Old Dec 5, 2003 | 07:14 PM
bcrl's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (AJ PwR)
3whp???
Old Dec 5, 2003 | 07:33 PM
esponet's Avatar
so thats about 1hp/$100 spent.
but 3hp you could gain or loose 3hp just on dynoing it on a different time of the day. or switching from one identical part to another identical part.
i myself did not gain anymore power by using spoon wires. its there for bling bling only
Old Dec 5, 2003 | 08:56 PM
Aquaman's Avatar
Just good for some bragging rights. They're just wires.
Old Dec 5, 2003 | 09:05 PM
Smitdog's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (Blk02EP)
OEM ITR's!
Old Dec 5, 2003 | 09:24 PM
Tweakmeister's Avatar
the quality is definately there, and so is the theory.
it's hard to quantify the gain from using wires like these (other than to say hp).
Old Dec 5, 2003 | 10:00 PM
Smitdog's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">the quality is definately there, and so is the theory.
it's hard to quantify the gain from using wires like these (other than to say hp).</TD></TR></TABLE>
Such Special words James....
Old Dec 7, 2003 | 02:00 PM
bcrl's Avatar
Default Re: SPOON HIGH TENSION PLUG WIRES (Smitdog)
oldschoolflava
Texas -OK -LA (Sales)
Dec 16, 2007 07:23 PM
djtsmith007
Dec 3, 2006 10:47 AM
TypeR0936
May 9, 2002 10:04 AM
itr501
Dec 14, 2001 07:44 AM
