After removing door panels and the clear plastic underneath, how to remove the white tacky stuff..
Like the title says.. Stripped the interior awhile back.. went to take the clear plastic off the door frame and there's the white tacky stuff holding it on.. How do you get it off? Even when very cold, the stuff seems very gooey.. like you can't really peel it off..
will paint thinner or something take this stuff off easily? suggestions?
they are gooey no matter what. are you trying to clean that stuff off, or just trying to remove the clear plastic to get to the door lock, etc.? If you just need to get to remove it for a while, just heat up the white gooey stuff and pull the clear plastic. When you're finished, just slap the plastic over the gooey stuff. You can reuse it.
goo-gone works, eh? I've got some of that laying around i think..
Yeah, I'm not trying to ever put the plastic back on or anything.. I need this stuff off permanently..
I don't think heating would be necessary.. it's not as tacky as the stuff that was on my Tacoma's door panels..
I used paint thinner and a rag. It makes a gooey sticky mess no matter what you plan to use. In the end, though the sticky stuff was all gone and the panel was like brand new.
Use PAINT thinnner and not LACQUER thinner. the latter will removw paint while the paint thinner will not.
good luck
good luck
That plastic stuff keeps the water out from hitting the door panel doesn't it? Unless you stripped the door panels too.
What's the importance of that clear plastic box held in the plastic do anyways?
Ed
Ed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur »</TD></TR><TR><TD CLASS="quote">That plastic stuff keeps the water out from hitting the door panel doesn't it? Unless you stripped the door panels too.
Ed</TD></TR></TABLE>
clear blastic box? i'll have to look for that when i go home..
and yes, the only thing left in my car at this point is the dash, steering wheel and seats..
RACEPAK
Paint and Body
Mar 11, 2013 03:29 PM
cleanep3
10
Jun 1, 2010 01:20 PM
-DC2-
17
Nov 25, 2003 04:38 PM
bemathew
Sep 16, 2001 09:01 AM
