Atts & check engine light came on
I was cruising down the road and my check engine light popped on then my Atts light popped on right after that. We checked the codes and it said 02 Sensor low. I don't understand why my Atts light popped on though.
ATTS just sucks.
j/k... but in reality, the atts "system" is really whack as far as other codes are concered. I had a friend with an SH and if he sneezed without covering his mouth his atts light would come on. But that could've just been his car... who knows.
anytime the CE light comes on the ATTS light will come on also. thats just the way they designed it.
i had the same problem once coming home from work. it turned out to be my gas cap. for some reason it was loose. i just had to reset the ECU and it was fine.
and i agree with Todd, ATTS does suck, its too sensitive. but it doesn't suck when i'm flyin' through corners.
