crank pulleys interchangeable?
Old Dec 3, 2003 | 06:32 AM
See Are X's Avatar
Default crank pulleys interchangeable?
are all B-series crank pulleys interchangeable? is the size difference going to make the timing marks wrong?
See Are X's Avatar
Default Re: crank pulleys interchangeable? (See Are X)
i need to put a jdm b16 crank pulley on a usdm b16
Old Dec 3, 2003 | 05:35 PM
See Are X's Avatar
up
Old Dec 3, 2003 | 06:51 PM
Padawan's Avatar
Darth ModerVader
The timing marks should be fine regardless of the pulley. Just out of curiosity, what leads you to believe the the JDM pulley is a different diameter than the USDM? I've never seen any info to indicate this, but then again, I can't recall any discussions regarding it either, so I suppose there's an off chance it's true. Either way, the pulley will be just fine.
4drctr420
Dec 11, 2011 06:04 AM
RTW DC2R
Feb 11, 2005 05:18 PM
pokemon
May 20, 2003 08:38 AM
